[Solved]DNS problem: NXDOMAIN looking up TXT for _acme-challenge
Hey there,
Im working the entiteit dat to get my wildcard goong, but I not able to solve my challenge issue.
My domain is: ccvitaal.nl
I ran this command:~$
sudo certbot certonly --server https://acme-v02.api.letsencrypt.org/directory --manual --preferred-challenges dns -d 'ccvitaal.nl,*.ccvitaal.nl'
Please deploy a DNS TXT record under the name
_acme-challenge.ccvitaal.nl with the following value:
mo8efpFyr2YZIJpyRfc5KCDPd1rkch9cWXTzVa2In8g
Before continuing, verify the record is deployed.
And
3-y7e0gUDEF2M85ILW2qxyLfJkrbxRgki6oFqr0DTBs
I added these values at my hosting provider
    Subdomain:@
Type:TXT
TTL:617
Address:_acme-challenge.ccvitaal.nl=mo8efpFyr2YZIJpyRfc5KCDPd1rkch9cWXTzVa2In8g
And
Subdomain:@
Type:TXT
TTL:617
Address:_acme-challenge.ccvitaal.nl=y7e0gUDEF2M85ILW2qxyLfJkrbxRgki6oFqr0DTBs
If I check my settings at unboundtext.com I receive positive results
;; ANSWER SECTION:
Ccvitaal.nl. 1000 IN TXT “_acme-challenge.ccvitaal.nl=mo8efpFyr2YZIJpyRfc5KCDPd1rkch9cWXTzVa2In8g”
Ccvitaal.nl. 1000 IN TXT “_acme-challenge.ccvitaal.nl=y7e0gUDEF2M85ILW2qxyLfJkrbxRgki6oFqr0DTBs”
But I receive an error in my terminal:
Waiting for verification…
Failed authorization procedure. ccvitaal.nl (dns-01): urn:ietf:params:acme:error:dns :: DNS problem: NXDOMAIN looking up TXT for _acme-challenge.ccvitaal.nl
    Domain: ccvitaal.nl
    Type: None
    Detail: DNS problem: NXDOMAIN looking up TXT for
I hope someone can help me out.
Kr
Server version: Apache/2.4.18 (Ubuntu)
Server built: 2018-06-07T19:43:03
Distributor ID: Ubuntu
Description: Ubuntu 16.04.5 LTS
Release: 16.04
Codename: xenial
Transit VPS and domain at argeweb.nl
Yes
I’m using a control panel to manage my site (no, or provide the name and version of the control panel):no
That's not how it works.
It should resemble something like:
_acme-challenge.ccvitaal.nl.	1000	IN	TXT	“mo8efpFyr2YZIJpyRfc5KCDPd1rkch9cWXTzVa2In8g”
At your hosting provider, you should specify _acme-challenge as the "subdomain" and just the strange looking value with all the numbers and letters as value, without any quotes.
Hello ,
Thx for Your swift reply.
I forgot to mention that I tried this as well.
But I just ran the command again and changed the settings.
So I changed the DNS settings. E.g.
Subdomain: _acme-challenge.ccvitaal.nl
TXT
Address:glTMop6r8C8IUzeXqCm6qQq
But unfortunately the same error.
    Domain: ccvitaal.nl
    Type: None
Any ideas left? I hope you see my error.
Kr
Hi @esorone,
You are not adding the txt records correctly, you are adding those txt records to subdomain _acme-challenge.ccvitaal.nl but you should add them to subdomain _acme-challenge.
Using below command should give you the last added txt records:
dig _acme-challenge.ccvitaal.nl txt
Right now to see your txt records you need to issue this command:
$ dig  _acme-challenge.ccvitaal.nl.ccvitaal.nl txt +short
"glTMop6r8C8IUzeXqCm6qQq_tCE1_su2qFqO_nkOo8s"
"mo8efpFyr2YZIJpyRfc5KCDPd1rkch9cWXTzVa2In8g"
Cheers,
sahsanu
Hello Sahsanu,
Thx, this was indeed the solution.
