DNS problem: NXDOMAIN looking up TXT
mattshi.com
certbot certonly -d *.mattish.com --manual --preferred-challenges dns --server https://acme-v02.api.letsencrypt.org/directory
dns-01 challenge for mattish.com
NOTE: The IP of this machine will be publicly logged as having requested this
certificate. If you're running certbot in manual mode on a machine that is not
your server, please ensure you're okay with that.
Are you OK with your IP being logged?
(Y)es/(N)o: y
Please deploy a DNS TXT record under the name
_acme-challenge.mattish.com with the following value:
TiD-QTgoQKTQ1OXHhhUvzSmO_sOmq2OSLIEboldK19g
Before continuing, verify the record is deployed.
Press Enter to Continue
Failed authorization procedure. mattish.com (dns-01): urn:ietf:params:acme:error:dns :: DNS problem: NXDOMAIN looking up TXT for _acme-challenge.mattish.com
    Domain: mattish.com
    Type: None
    Detail: DNS problem: NXDOMAIN looking up TXT for
My web server is (include version): Nginx
The operating system my web server runs on is (include version): Debian 9
My hosting provider, if applicable, is: Godaddy
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot):0.28.0
I have added a TXT record and run :
dig -t TXT _acme-challenge.mattshi.com
output:
; <<>> DiG 9.10.3-P4-Debian <<>> -t TXT _acme-challenge.mattshi.com
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 10703
;; flags: qr rd ra; QUERY: 1, ANSWER: 1, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 512
;; QUESTION SECTION:
;_acme-challenge.mattshi.com. IN TXT
;; ANSWER SECTION:
_acme-challenge.mattshi.com. 3599 IN TXT "TiD-QTgoQKTQ1OXHhhUvzSmO_sOmq2OSLIEboldK19g"
;; Query time: 65 msec
;; SERVER: 8.8.8.8#53(8.8.8.8)
;; WHEN: Mon Jan 21 06:55:24 EST 2019
;; MSG SIZE rcvd: 112
I think my record is valid.But I still got error.
Hi @SneakyTurt1e
I see, you have already checked your domain via mattshi.com - Make your website better - DNS, redirects, mixed content, certificates
This looks good.
TXT - Entries
Domainname TXT Entry Status āˆ‘ Queries āˆ‘ Timeout
mattshi.com ok 1 0
www.mattshi.com 1 0
_acme-challenge.mattshi.com oA3rdv-T9WcSGlXBDW5_R4fTMiEYvPqroImxao5uyNU looks good 1 0
_acme-challenge.www.mattshi.com Name Error - The domain name does not exist 1 0
_acme-challenge.mattshi.com.mattshi.com Name Error - The domain name does not exist 1 0
_acme-challenge.www.mattshi.com.www.mattshi.com Name Error - The domain name does not exist 1 0
But therre
you are checking mattish.com without an i. There is no txt entry defined.
So it looks like a typo.
Thank you very much for your help, I made a very stupid mistake :rofl:. Please close it.
Typos happens. And typos are first always invisible.
I know that! :wink:
