DNS problem: NXDOMAIN looking up TXT
My domain is: odaku.net
sudo certbot --server https://acme-v02.api.letsencrypt.org/directory -d odaku.net -d www.odaku.net --manual --preferred-challenges dns-01 certonly
Challenge failed for domain odaku.net
Challenge failed for domain www.odaku.net
dns-01 challenge for odaku.net
dns-01 challenge for www.odaku.net
    Domain: odaku.net
    Type: dns
    Detail: DNS problem: NXDOMAIN looking up TXT for
    _acme-challenge.odaku.net - check that a DNS record exists for this
    domain
    Domain: www.odaku.net
    Type: dns
    _acme-challenge.www.odaku.net - check that a DNS record exists for
    this domain
nginx
Ubuntu 20.04.2 LTS (Focal Fossa)
Go Daddy
Yes
N
certbot 0.40.0
Welcome to the Let's Encrypt Community :slightly_smiling_face:
I don't see the TXT records either. Did you add them to your DNS?
https://toolbox.googleapps.com/apps/dig/#TXT/
I have TXT records for that for both _acme-challenge.odaku.net and _acme-challenge.www.odaku.net. What is the tool you have used above. I ran the following commands and the results below:
$dig _acme-challenge.www.odaku.net TXT
; <<>> DiG 9.16.1-Ubuntu <<>> _acme-challenge.www.odaku.net TXT
;; global options: +cmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 6255
;; flags: qr rd ra; QUERY: 1, ANSWER: 0, AUTHORITY: 0, ADDITIONAL: 1
;; OPT PSEUDOSECTION:
; EDNS: version: 0, flags:; udp: 65494
;; QUESTION SECTION:
;_acme-challenge.www.odaku.net. IN TXT
;; Query time: 252 msec
;; SERVER: 127.0.0.53#53(127.0.0.53)
;; WHEN: Fri Aug 13 22:59:31 UTC 2021
;; MSG SIZE rcvd: 58
And for odaku.net:
$ dig _acme-challenge.odaku.net TXT
; <<>> DiG 9.16.1-Ubuntu <<>> _acme-challenge.odaku.net TXT
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NXDOMAIN, id: 22237
;_acme-challenge.odaku.net. IN TXT
;; Query time: 256 msec
;; WHEN: Fri Aug 13 23:00:50 UTC 2021
;; MSG SIZE rcvd: 54
I used Google dig. There were no TXT records found in my search OR yours. Are you sure you're adding them to the correct DNS zone?
What you have is:
nslookup -q=txt _acme-challenge.odaku.net.odaku.net
_acme-challenge.odaku.net.odaku.net     text =
        "Eb5a0nW5F4z_pJzFNdT9DAmlvBOMo17EQI06R6VaoSg"
nslookup -q=txt _acme-challenge.www.odaku.net.odaku.net
_acme-challenge.www.odaku.net.odaku.net text =
        "3LtYG5IfCVwjnxs_RL3fXy-_Vrr2I6fvHCzE8_3PIgo"
When creating the TXT record, don't include the domain name in the domain zone.
I concur. You beat me to it, @rg305. :beer:
You guys are awesome!
I deleted the existing TXT records and created new ones and this time I used _acme-challenge and _acme-challenge.www and it worked!
Is "Go Daddy" appending the DNS names to the TXT record? Because this does not happen on my other domain on AWS.
Thank you!
Different DNS systems handle this differently.
Some apparently need some AI added; as a human would catch that immediately. LOL
So it depends, and it should be tested to see how your individual DNS systems react.
Perhaps, when adding an FQDN entry, using a period at the end could help too.
YMMV.
Glad to see that you got the cert :slight_smile:
Cheers from Miami :beers:
#FreeCuba
Thanks for the explanation! One more upvote for restating the benefits of AI .. ha ha...
