DNS problem: NXDOMAIN looking up TXT
My domain is: nyresidentsalliance.org
I ran this command:sudo certbot -d $DOMAIN -d $WILDCARD --manual --preferred-challenges dns certonly
Failed authorization procedure. nyresidentsalliance.org (dns-01): urn:ietf:params:acme:error:dns :: DNS problem: NXDOMAIN looking up TXT
for _acme-challenge.nyresidentsalliance.org - check that a DNS record exists for this domain
    Domain: nyresidentsalliance.org
    Type: None
    Detail: DNS problem: NXDOMAIN looking up TXT for
bitnami@ip-172-26-3-150:~$ httpd -v
Server version: Apache/2.4.41 (Unix)
Server built: Feb 7 2020 11:05:17
NAME="Ubuntu"
VERSION="16.04.6 LTS (Xenial Xerus)"
ID=ubuntu
ID_LIKE=debian
PRETTY_NAME="Ubuntu 16.04.6 LTS"
VERSION_ID="16.04"
HOME_URL="http://www.ubuntu.com/"
SUPPORT_URL="http://help.ubuntu.com/"
BUG_REPORT_URL="http://bugs.launchpad.net/ubuntu/"
VERSION_CODENAME=xenial
UBUNTU_CODENAME=xenial
My hosting provider, if applicable, is: AWS Lightsail
I can login to a root shell on my machine (yes or no, or I don't know):Yes
I'm using a control panel to manage my site (no, or provide the name and version of the control panel):No
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot):certbot 0.31.0
Hello @queenian Welcome to the community.
I'm certainly not an expert but at first glance it looks like you may have an issue with your server time configuration.
Not Before Tue, 29 Dec 2020 01:18:06 GMT
Not After Mon, 29 Mar 2021 01:18:06 GMT
https://www.ssllabs.com/ssltest/analyze.html?d=nyresidentsalliance.org
https://crt.sh/?q=nyresidentsalliance.org
Hope this helps at least with a starting point
The ssl was working fine, and I think there was some problem when I tried to renew it (it was due to renewal on 3/29). After the renewal failed, then I tried to create to new one, then I got the above error. I think the server time is correct,
Last login: Mon Mar 29 14:45:00 2021 from 72.21.217.129
bitnami@ip-172-26-3-150:~ date Mon Mar 29 17:19:44 UTC 2021 bitnami@ip-172-26-3-150:~
I keep getting this error each time I create to execute this command:
error I got::
Please help.
Welcome to the Let's Encrypt Community, Vito :slightly_smiling_face:
You probably already know this, but you need to create new TXT records each time you create or renew a certificate. Since you're using manual authentication (without manual-auth-hook or manual-cleanup-hook scripts to add and remove the TXT records automatically), you'll need to add and remove the specified TXT records yourself, being sure to give adequate time for the TXT records to propagate. You can check for the propagation of the TXT records with dig. Once your certificate has been successfully issued, you can remove all existing _acme-challenge TXT records.
Here's what currently exists:
id 8031
opcode QUERY
rcode NOERROR
flags QR RD RA
;QUESTION
_acme-challenge.nyresidentsalliance.org. IN TXT
;ANSWER
_acme-challenge.nyresidentsalliance.org. 299 IN TXT "LSz1DWF-9igLH_u-pBVL8VMy79oRN9DXyQLfOvnO5AU"
;AUTHORITY
;ADDITIONAL
Example command:
sudo certbot certonly --cert-name nyresidentsalliance.org --manual --preferred-challenges dns -d "nyresidentsalliance.org,*.nyresidentsalliance.org" --keep
The command above will require creating 2 TXT records, both with a host of _acme-challenge.nyresidentsalliance.org, but with different values.
Side note:
You cannot use sudo certbot renew when using manual authentication because the renew function runs "non-interactively", meaning that it doesn't pause to let you manually add the TXT records. Hence why you would need manual-auth-hook and manual-cleanup-hook scripts.
You might consider using acme-dns to help you automate your renewals.
Thanks for your help. I gave it enough time to refresh before I hit the return key. It is working now.
Beautiful! :partying_face:
Glad to hear it! :smiley:
