Certbot not finding acme challenge. DNS TXT seems OKm
My domain is: baffleplates.com
I ran this command: sudo certbot certonly --manual --preferred-challenges dns
It produced this output:QTb8m-maSA_4sDwg36_pM1g55qDr6_fEqErPSM0PQ9E
Before continuing, verify the record is deployed.
Press Enter to Continue
Waiting for verification…
Failed authorization procedure. baffleplates.com (dns-01): urn:ietf:params:acme:error:dns :: DNS problem: NXDOMAIN looking up TXT for _acme-challenge.baffleplates.com
    Domain: baffleplates.com
    Type: None
    Detail: DNS problem: NXDOMAIN looking up TXT for
My web server is (include version): N/A doing it manually
The operating system my web server runs on is (include version):Debian 9 Linux d1 4.9.0-8-amd64 #1 SMP Debian 4.9.144-3.1 (2019-02-19) x86_64 GNU/Linux
My hosting provider, if applicable, is: DNS hosted by godaddy; site hosted on my home PC
I can login to a root shell on my machine (yes or no, or I don’t know):Y
I’m using a control panel to manage my site (no, or provide the name and version of the control panel):No
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): 0.28.0
You probably needed to wait longer after setting the record.
I set the TTL to 1/2 hour (the minimum on godaddy DNS management) and waited for more than that before hitting return.
I put some screenshots on the web
mips-erp.com/DNS/DNS.png
mips-erp.com/DNS/MoreDNS.png which shows text hidden on the previous png
mips-erp.com/DNS/certbot.png
TTL doesn’t affect the way Let’s Encrypt looks up records.
I don’t doubt you setup the record the right way, but the only explanation seems to be that GoDaddy took a long time to apply the updates to the nameservers.
Let’s Encrypt can see it now:
  Type:   unauthorized
  Detail: Incorrect TXT record
  "Ql66D0mB8Bd_hBDcRIuXNlv9ew0TZwt_n4Vkt7EQn6Q" found at
Thanks. It has now worked.
It would be useful if certbot output was timestamped.
I have put the correct godaddy DNS image on the Net. mips-erp.com/DNS/DNS2.png
I was confused because I missed the point that “Please deploy a DNS TXT record under the name
_acme-challenge.baffleplates.com” meant named “_acme-challenge” in the DNS record for my domain. Maybe the documentation could make this clear.
Thanks for your help
