Cert not renewing in Plesk (auto or manual)
My domain is: stevendtaylor.com
I ran this command: n/a
It produced this output: n/a
My web server is (include version): DV w/SSDs (CentOS 6) - Level 1 (mt) media temple
The operating system my web server runs on is (include version): CentOS 6.5 (Final)‬
My hosting provider, if applicable, is: (mt) media temple
I can login to a root shell on my machine (yes or no, or I don’t know): I don’t know
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): Plesk version 12.5.30 Update #79, last updated at Jan 15, 2019 12:38 AM
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): IDK
Hello,
I’ve installed a Let’s Encrypt cert for https://stevendtaylor.com/ inside (mt) media temple / Plesk however, it’s not renewing automatically. I also tried to manually renew the cert inside Plesk today but that didn’t work either. I was assuming that the cert would auto extend past April 3rd, 2019. Can you help me fix this please? I waited for auto renew, that didn’t work. Then I tried a manual renew, and this didn’t work either.
Please advise very soon. Thank you.
  • Steven T.
Hi @sdtaylor0761
are there some error messages? Did you ask your hoster?
Plesk is a "closed system", so it should work.
But: Checking your domain perhaps there is a problem (via https://check-your-website.server-daten.de/?q=stevendtaylor.com ):
http://stevendtaylor.com/
192.124.249.10 301 https://stevendtaylor.com/ 2.994 A
http://www.stevendtaylor.com/
192.124.249.10 301 http://stevendtaylor.com/ 0.250 D
https://www.stevendtaylor.com/
192.124.249.10 301 https://stevendtaylor.com/ 5.607 B
192.124.249.10 200 7.167 B
http://www.stevendtaylor.com/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
192.124.249.10 301 http://stevendtaylor.com/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 0.410 D
Visible Content: 301 Moved Permanently nginx
192.124.249.10 503 0.764 S
Service Unavailable
Visible Content: Steven D. Taylor – Photographic Artist – Nature Lover Check Back Later ! Website will be available soon © StevenDTaylor.com 2006-2018
There is a
Server: Sucuri/Cloudproxy
But the last check - http + non-www + /.well-known/acme-challenge - there is a http status 503.
So it may be impossible that Letsencryt validates your domain name.
Why is there a 503? A http status 404 - Not Found - is expected.
