SSL Issue on Plesk
My domain is: agapeelementaryacademy.com
I ran this command: nothing
It produced this output: The SSL/TLS certificate cannot be renewed automatically because the required data is missing. To renew the certificate, reissue it manually.
My hosting provider, if applicable, is: Serverwala
I can login to a root shell on my machine (yes or no, or I don't know): no
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): Plesk Obsidian 18.0.49
Hi @vaibhav, and welcome to the LE community forum :slight_smile:
Did you get this cert for that system [yesterday]?:
crt.sh | 8375488918
Yes Sir
Please help to resolved this issue.
Yes Sir, Please Help
The problem is within Plesk panel.
I'm not sure this is the best place to get help with such problems.
And, if you can't login as root, then we can't really do much troubleshooting.
Have you spoken with your HSP?
Here is a link I found for them Contact Us | Serverwala Cloud Data Center Pvt. Ltd
Plesk support says, problem is at let's encrypt server end. Please help to resolve this issue.
Plesk support team replied:
"Let me clarify how Lets Encrypt certificate issuing works. Certificate is issued by Lets Encrypt servers. When I tried to connect to the Lets encrypt server https://acme-v02.api.letsencrypt.org, it fails again with the same response below:
 C:\Users\Administrator>curl -v https://acme-v02.api.letsencrypt.org
 Trying 172.65.32.248:443...
 Connected to acme-v02.api.letsencrypt.org (172.65.32.248) port 443 (#0)
 schannel: disabled automatic use of client certificate
 ALPN: offers http/1.1
 schannel: next InitializeSecurityContext failed: Unknown error (0x80092012) - The revocation function was unable to check revocation for the certificate.
 Closing connection 0curl: (35) schannel: next InitializeSecurityContext failed: Unknown error (0x80092012) - The revocation function was unable to check revocation for the certificate.
please help and let us know for further update.
Check on high priority.
If it was on Let's Encrypt's side, we'd probably be seeing many more reports about it.
Can you test these commands as well please:
curl -I http://x1.c.lencr.org
curl -I http://r3.o.lencr.org
