Auto renewal of certificates
My domain is: newcastle-seo.co.uk
My web server is (include version): Hosted on Fasthost dedicated server
My hosting provider, if applicable, is: Fasthost - dedicated server
Using Plesk
Hi @webpaje
what's your question? There is a valid Letsencrypt certificate.
If you use Plesk, you should only use Plesk, not an additional client.
If your Plesk doesn't work, it's a problem your hoster has to fix.
Hi
sorry wasnt clear enough. I can create a certificate using Plesk - have done for many domains . If i look at the details in Plesk it shows that the certificates are set up as auto renewal. However when it comes to renewal i have to do that myself in Plesk. I queried this with Fasthost and they said i would have to contact Lets Encrypt. I use it for many domains and it is the same situation for all of them . Hope thats more specific
If you have to initiate the renew manual, your Plesk is buggy. Your hoster has to fix that, that's not a Letsencrypt problem.
Client doesn't start -> client problem.
PS: The certificate expires 2020-08-10, so it's expected that it's not renewed now.
Normally, certificates are renewed if they are less then 30 days valid.
Many thanks for the help, will try fasthost again
