why do i have trouble with https to server panel ?
also, do i have to make a re-routing from http:// mydomain to https://mydomain ? or is there a setting that re-routs http to https ?
Regards,
Frank
Regards,
Frank
Hi @Frank1000
your https://server.uptoconcept.com/ is good, a new Letsencrypt certificate.
But your port 8443 has a wrong certificate. So accept the wrong certificate, log in. And check your Plesk certificate configuration.
I don't use Plesk. But there may be an option to secure this internal port:
It's the same problem there:
If you have a lot of domains, then use the admin tool only with one domain.
If you don't want that, you have to create one certificate with a lot of domain names and install that.
But I don't know if Plesk supports that.
ok thank you
