I ran this command:sudo /opt/bitnami/ctlscript.sh start
It produced this output: Job for bitnami.service failed because the control process exited with error code.
See "systemctl status bitnami.service" and "journalctl -xe" for details.
My web server is (include version):Apache (Bitnami)
The operating system my web server runs on is (include version):"Debian GNU/Linux 11 (bullseye)
My hosting provider, if applicable, is: AWS Lightsail (LAMP not the wordpress)
I can login to a root shell on my machine (yes or no, or I don't know): - Yes
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): - No
or certbot-auto --version
if you're using Certbot):- certbot 1.12.0
Guide I followed - Tutorial: Using Letβs Encrypt SSL certificates with your LAMP instance in Amazon Lightsail | Lightsail Documentation
My website and app was working perfectly until i tried to renew my website and the end message was successful for renew but when i check my website ssl exiry it same as before renew (09 Feb 2023). Today i wen back to same guide and followed the step 7 : Step 7: Create links to the Letβs Encrypt certificate files in the Apache server directory and ran ```
sudo /opt/bitnami/ctlscript.sh stop
then sudo /opt/bitnami/ctlscript.sh start
but it start showing the error.
The journalctl -xe response
Feb 04 03:08:33 ip-172-26-3-59 systemd[1]: bitnami.service: Unit process 105610>
Feb 04 03:08:33 ip-172-26-3-59 systemd[1]: Failed to start LSB: bitnami init sc>
ββ Subject: A start job for unit bitnami.service has failed
ββ Defined-By: systemd
ββ Support: https://www.debian.org/support
ββ
ββ A start job for unit bitnami.service has finished with a failure.
ββ
ββ The job identifier is 107777 and the job result is failed.
Feb 04 03:08:33 ip-172-26-3-59 systemd[1]: bitnami.service: Consumed 1.383s CPU>
ββ Subject: Resources consumed by unit runtime
ββ
ββ The unit bitnami.service completed and consumed the indicated resources.
Feb 04 03:08:39 ip-172-26-3-59 sshd[1057688]: Received disconnect from 52.174.2>
Feb 04 03:08:39 ip-172-26-3-59 sshd[1057688]: Disconnected from authenticating >
lines 1616-1638/1638 (END)
Feb 04 03:08:33 ip-172-26-3-59 systemd[1]: bitnami.service: Unit process 1056103 (php-fpm) remains running after unit stopped.
Feb 04 03:08:33 ip-172-26-3-59 systemd[1]: bitnami.service: Unit process 1056104 (php-fpm) remains running after unit stopped.
Feb 04 03:08:33 ip-172-26-3-59 systemd[1]: bitnami.service: Unit process 1056105 (php-fpm) remains running after unit stopped.
Feb 04 03:08:33 ip-172-26-3-59 systemd[1]: bitnami.service: Unit process 1056106 (php-fpm) remains running after unit stopped.
Feb 04 03:08:33 ip-172-26-3-59 systemd[1]: bitnami.service: Unit process 1056107 (php-fpm) remains running after unit stopped.
Feb 04 03:08:33 ip-172-26-3-59 systemd[1]: bitnami.service: Unit process 1056108 (php-fpm) remains running after unit stopped.
Feb 04 03:08:33 ip-172-26-3-59 systemd[1]: bitnami.service: Unit process 1056109 (php-fpm) remains running after unit stopped.
Feb 04 03:08:33 ip-172-26-3-59 systemd[1]: Failed to start LSB: bitnami init script.
ββ
ββ
Feb 04 03:08:33 ip-172-26-3-59 systemd[1]: bitnami.service: Consumed 1.383s CPU time.
ββ
Feb 04 03:08:39 ip-172-26-3-59 sshd[1057688]: Received disconnect from 52.174.28.224 port 58200:11: Bye Bye [preauth]
Feb 04 03:08:39 ip-172-26-3-59 sshd[1057688]: Disconnected from authenticating user root 52.174.28.224 port 58200 [preauth]
sudo /opt/bitnami/ctlscript.sh status
apache not running
mariadb not running
php-fpm not running
My website is down and i am not able to find solutions for this. I also noob in these. Please help me out
