Unclear how to setup QNAP NAS using Cerbot with Let's Encrypt
My domain is: llanblethian.org.uk
Sounds like a question you should be asking QNAP. Here are some resources that may help:
https://www.qnap.com/en/how-to/faq/article/how-do-i-install-a-lets-encrypt-ssl-certificate-for-a-custom-ddns-domain-in-qts
https://forum.qnap.com/viewtopic.php?t=144434
Not sure what CERTBOT option I should use where the QNAP NAS is running on macOS with Apache?
QNAP tech support are saying running their webserver using their application is outside their scope for helping me. I’m just hoping someone else has a Mac and successfully setup a SSL Certificate using QNAP Webserver application on a Mac
Are you quite sure of this? Because I'd expect the QNAP NAS is running its own OS, which is not macOS.
I know this is what my QNAP is running
# uname -a
Linux NAS3BA281 4.2.8 #2 SMP Fri Oct 24 14:08:03 CST 2025 armv7l GNU/Linux
Bruce you’re right it’s running a linux I believe which I access on my Mac, so I’m hopingI fond the exact way I choose the correct option from Cerbot’s menu of options to install Cerbot and the full step by step process to setup SSL on my QNAP Webserver self hosted website. Can you assist me with this please?
Unfortunately, it is all too common for providers to offer LE or something like this, but don't really give any support for it.
I don't have a qnap device to help, myself, but there's usually a panel on this kind of device you can access that should have some sort of interface for it, checking that would be the first step.
