I can see in the hardware firewall logs it’s passing both 80 and 443 to the apache server.
I did add forwarding from port 80 to 443 in the website’s .conf file.
<VirtualHost *:80>
ServerName binderhospital.com
ServerAlias www.binderhospital.com
ServerAdmin info@binderhospital.com
DocumentRoot /var/www/BinderHosp
RewriteEngine on
RewriteRule ^ https://%{SERVER_NAME}%{REQUEST_URI} [END,QSA,R=permanent]
RewriteEngine on
RewriteCond %{SERVER_NAME} =www.binderhospital.com [OR]
RewriteCond %{SERVER_NAME} =binderhospital.com
My domain is: binderhospital.com
I ran this commands:
certbot renew --apache
certbot renew --standalone --preferred-challenges tls-sni
Processing /etc/letsencrypt/renewal/binderhospital.com.conf
tls-sni-01 challenge for binderhospital.com
tls-sni-01 challenge for www.binderhospital.com
Waiting for verification…
Attempting to renew cert from /etc/letsencrypt/renewal/binderhospital.com.conf produced an unexpected error: Failed authorization procedure. www.binderhospital.com (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Timeout during connect (likely firewall problem), binderhospital.com (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Timeout during connect (likely firewall problem). Skipping.
Server: Apache/2.4.10 (Raspbian)
I can login to a root shell on my machine
Yes
No
