[redacted]
certbot renew
Processing /etc/letsencrypt/renewal/[redacted].conf
http-01 challenge for [redacted]
Waiting for verification…
Attempting to renew cert ([redacted]) from /etc/letsencrypt/renewal/[redacted].conf produced an unexpected error: Failed authorization procedure. [redacted] (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://[redacted]/.well-known/acme-challenge/rv3491PbwHWwAraSQv1SXHJcWmPM-BEsvWzR2QQD7zA: Timeout during connect (likely firewall problem). Skipping.
/etc/letsencrypt/live/[redacted]/fullchain.pem (failure)
    Domain: [redacted]
    Type: connection
    Detail: Fetching
Apache version 2.4.18
Ubuntu Linux 16.04
Amazon ec2
Yes I can
webmin
certbot 0.28.0
Hi @ahmedvolks,
It looks like you do have a firewall blocking connections on port 80, which is preventing the validation from succeeding. Could this be in your Amazon EC2 policies? They often have defaults that block quite a lot of ports.
You might also want to use Webmin's built-in Let's Encrypt support instead of Certbot (although that won't fix the firewall problem, which would affect Webmin just as much as Certbot).
Hi Schoen,
Thank you for your reply, Actually I opened the 80 and already opened the 443 as below,
Inbound:
Type Protocol Port Range Source Description
SMTP TCP 25 0.0.0.0/0
HTTP TCP 80 0.0.0.0/0
POP3 TCP 110 0.0.0.0/0
IMAP TCP 143 0.0.0.0/0
HTTPS TCP 443 0.0.0.0/0
SMTPS TCP 465 0.0.0.0/0
IMAPS TCP 993 0.0.0.0/0
POP3S TCP 995 0.0.0.0/0
Outbound
All traffic All All 0.0.0.0/0
I also tried webmin now and the log tail is shown below:
2019-01-29 04:45:22,417:DEBUG:certbot.reporter:Reporting to user: The following errors were reported by the server:
Domain: [redacted]
Type: connection
Detail: Fetching http://[redacted]/.well-known/acme-challenge/SCytUPel0iSDnLTJz3GLFxZOaKZOC0l3hAD1Z_wHZ0M: Timeout during connect (likely firewall problem)
To fix these errors, please make sure that your domain name was entered correctly and the DNS A/AAAA record(s) for that domain contain(s) the right IP address. Additionally, please check that your computer has a publicly routable IP address and that no firewalls are preventing the server from communicating with the client. If you’re using the webroot plugin, you should also verify that you are serving files from the webroot path you provided.
[continuation of log redacted]
It still looks filtered by a firewall to me from here. You should check for both host and network firewalls (like both ufw and policy groups), because either can interfere with connections.
I added port 80 as below and it worked.but the port 80 was not used before, is this true?
ufw allow 80
To Action From
80 ALLOW Anywhere
Any way to hide the details related to my domain please??
There is a change related to limiting the use of port 443 in validations which was announced in January of last year and formally scheduled in October of last year.
In order to prepare for this change, Certbot's default behavior was changed in releases starting last month:
It's something of an oversimplification to say "port 80 was not used before", but it's true that there's been a recent change which has meant that Certbot users who were validating over port 443 have been switched to validating over port 80. We've been trying to accelerate this process because in the near future the Let's Encrypt certificate authority will disable TLS-SNI-01 validations entirely, as described in several of the posts I linked to.
I edited your posts in this thread to remove the references to your domain.
Thank you very much for this :slight_smile:
