certbot renew --dry-run
Processing /etc/letsencrypt/renewal/e3.dtadata.com.conf
Starting new HTTPS connection (1): acme-staging-v02.api.letsencrypt.org
http-01 challenge for e3.dtadata.com
Waiting for verification…
Challenge failed for domain e3.dtadata.com
Attempting to renew cert (e3.dtadata.com) from /etc/letsencrypt/renewal/e3.dtadata.com.conf produced an unexpected error: Some challenges have failed… Skipping.
/etc/letsencrypt/live/e3.dtadata.com/fullchain.pem (failure)
    Domain: e3.dtadata.com
    Type: connection
    Detail: Fetching
    http://e3.dtadata.com/.well-known/acme-challenge/U4UCH8bN5ga2VvUhxq56RHb835nBIuftxyw1_lcs7mE:
My web server is (include version): Apache 2.4.6
The operating system my web server runs on is (include version): CentOS 7
I’m using a control panel to manage my site: no
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.38.0
Interesting...
Can you please run this command
certbot certifcates
And post the results
Cheers
Trying to connect to http://e3.dtadata.com/ times out for me too.
Is there a firewall blocking port 80?
Can you connect to it?
From other ISPs?
I can’t even ping your IP, but I can access other IPs on the same /24, so it seems like it’s probably a firewall issue.
