Timeout during connect
My domain is: repositorio.leon.uia.mx
I ran this command: certbot-auto --dry-run renew
Processing /etc/letsencrypt/renewal/repositorio.leon.uia.mx.conf
http-01 challenge for repositorio.leon.uia.mx
Waiting for verification…
Challenge failed for domain repositorio.leon.uia.mx
Attempting to renew cert (repositorio.leon.uia.mx) from /etc/letsencrypt/renewal/repositorio.leon.uia.mx.conf produced an unexpected error: Some challenges have failed… Skipping.
/etc/letsencrypt/live/repositorio.leon.uia.mx/fullchain.pem (failure)
    Domain: repositorio.leon.uia.mx
    Type: connection
    Detail: Fetching
    http://repositorio.leon.uia.mx/.well-known/acme-challenge/5NERg1qoCj1v9QSkOFp_BiRbGTBUR4IEZvNejV25_Xc:
My web server is (include version): apache2 (2.4.25-3+deb9u7)
The operating system my web server runs on is (include version): devuan ascii (equiv. debian stretch)
My hosting provider, if applicable, is: not applicable
I’m using a control panel to manage my site : no
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.36.0
I did some tests from other networks, and they all can reach this server, at both port 80 and 443.
It seems likely that your server has blocked the Let’s Encrypt validation hosts.
Do you have anything like fail2ban installed?
We don´t have fail2ban installed, the firewall rules for this server are off, and the policy is ACCEPT. There is a firewall covering this server, but I have no access to it, but have been assured that it is not blocking access to ports 80 or 443 -my tests also show this is the case, it does accept traffic and responds on both ports-
Hi @cacho
checking your domain that looks bad ( https://check-your-website.server-daten.de/?q=repositorio.leon.uia.mx ):
repositorio.leon.uia.mx Refused yes 1 0
www.repositorio.leon.uia.mx Refused yes 1 0
repositorio.leon.uia.mx A 192.100.195.113 Mexico City/Mexico (MX) - Universidad Iberoamericana, A.C. No Hostname found no
But an older check (this morning) was good:
repositorio.leon.uia.mx A 192.100.195.113 Mexico City/Mexico (MX) - Universidad Iberoamericana, A.C. No Hostname found yes 1 0
AAAA yes
www.repositorio.leon.uia.mx Name Error yes 1 0
/.well-known/acme-challenge/random-filename works. But using Website Uptime Test: Check Website Status | Uptrends all is red:
Compare the list of name servers (current check - older check). Looks like a problem.
This is very strange. I put a file there for testing as the certbot client removes the random file when it is done, it shows all green.
The domain has four nameservers, geographically independent, and all of them have the proper data for repositorio.leon.uia.mx now, www.repositorio.leon.uia.mx does not exist, and is not wanted.
This domain has been working with letsencrypt for a couple of years now, and this is the strangest part: Every check you made with uptrends.com is reflected in my logs, but not one access attempt is logged for letsencrypt´s certbot runs.
Is there something that can be done?
A potentially confusing factor is that it looks like this site shows 404 Not Found errors as red also, so you could get very visually different results if you test with a file that exists and again with one that doesn't exist.
Sorry, that was a false alarm. @schoen has the correct idea. Checked my own domain with the /.well-known/acme-challenge/not-existing-file - it's the same picture, all is red.
Good to know - uptrends must be used with an address with http status 200.
Ok, so the server is responding properly, but it still is not being accesed by letsencrypt to validate the certificates.
What else can I do?
Change that link to
http://repositorio.leon.uia.mx/.well-known/acme-challenge/a
to check, if it isn't a configuration problem well-known vs. well-known/acme-challenge.
Checked that url there is a minor problem - https://check-your-website.server-daten.de/?q=repositorio.leon.uia.mx%2F.well-known%2Fa
http://repositorio.leon.uia.mx/ 302 https://repositorio.leon.uia.mx/ 0.427 A
192.100.195.113 200 0.437 H
https://repositorio.leon.uia.mx/.well-known/a
192.100.195.113 302 http://repositorio.leon.uia.mx/ 2.176 F
https://repositorio.leon.uia.mx/ 200 2.327 B
http://repositorio.leon.uia.mx/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
192.100.195.113 404 0.424 A
Not Found
Visible Content: Not Found The requested URL /.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de was not found on this server. Apache/2.4.25 (Debian) Server at repositorio.leon.uia.mx Port 80
It's redirected to /.
But: Try it again (one time): The main problem: Is there again a timeout? If yes, that's fatal. Perhaps a global firewall.
Do you have access to the name server? If yes, use one time dns-validation and --manual, that should always work.
Ok, I changed the files to that directory, they still work. I´ll try dns-validation.
With DNS validation that server was renewed. Now I have several others failing, but they behave a little bit different.
They all have access logs indicating letsencrypt was able to fetch the files, but they all present the same error, timeout, likely because of a firewall. How can this be if the logs have the appropiate records?
This is one of them:
3.14.255.131 - - [08/Aug/2019:06:22:45 -0500] “GET /.well-known/acme-challenge/q4VQYD70qADIdx0Hcxz_yXIll5LjrQ56lyETq6kPVHk HTTP/1.1” 200 308 “-” “Mozilla/5.0 (compatible; Let’s Encrypt validation server; +https://www.letsencrypt.org)”
34.222.229.130 - - [08/Aug/2019:06:22:46 -0500] “GET /.well-known/acme-challenge/q4VQYD70qADIdx0Hcxz_yXIll5LjrQ56lyETq6kPVHk HTTP/1.1” 200 308 “-” “Mozilla/5.0 (compatible; Let’s Encrypt validation server; +https://www.letsencrypt.org)”
18.197.227.110 - - [08/Aug/2019:06:22:46 -0500] “GET /.well-known/acme-challenge/q4VQYD70qADIdx0Hcxz_yXIll5LjrQ56lyETq6kPVHk HTTP/1.1” 200 308 “-” “Mozilla/5.0 (compatible; Let’s Encrypt validation server; +https://www.letsencrypt.org)”
I can´t see any errors there. This is now for server “www.dialogosfeycultura.org”, which is in the same network segment.
Those IP addresses are from the Let's Encrypt staging environment. Something specific to the staging environment is that it performs validation from multiple servers at the same time (Validating challenges from multiple network vantage points).
There are three remote VAs and two of the three remote VAs must succeed for the validation to succeed.
Right now, I see 4 requests arriving for a single challenge. I'm not sure if the above statement is still true about the required threshold for success, but I think it's the most likely explanation for your symptoms.
You're correct. That's still the required threshold in the staging environment. You might also notice we've also been performing multiple challenge validation requests in the production environment as well but presently it is information gathering only and isn't being used to influence the overall validation result in that env.
Thank you all for your time and suggestions, it was a routing problem, the servers answered from a different network than the one used to reach them for some reason, it is now fixed and working again.
