Domain: abr.eplus.net
./certbot-auto -v renew --preferred-challenges http --debug-challenges --dry-run
Root logging level set at 10
Processing /etc/letsencrypt/renewal/abr.eplus.net.conf
Requested authenticator <certbot._internal.cli.cli_utils._Default object at 0x7f9beb5aa750> and installer <certbot._internal.cli.cli_utils._Default object at 0x7f9beb5aa750>
Var dry_run=True (set by user).
Var server=set([‘staging’, ‘dry_run’]) (set by user).
Var account=set([‘server’]) (set by user).
Starting new HTTP connection (1): ocsp.int-x3.letsencrypt.org:80
http://ocsp.int-x3.letsencrypt.org:80 “POST / HTTP/1.1” 200 527
OCSP response for certificate /etc/letsencrypt/archive/abr.eplus.net/cert6.pem is signed by the certificate’s issuer.
OCSP certificate status for /etc/letsencrypt/archive/abr.eplus.net/cert6.pem is: OCSPCertStatus.GOOD
Should renew, less than 30 days before certificate expiry 2020-04-02 04:36:08 UTC.
Requested authenticator webroot and installer nginx
Single candidate plugin: * nginx
Description: Nginx Web Server plugin
Interfaces: IAuthenticator, IInstaller, IPlugin
Entry point: nginx = certbot_nginx._internal.configurator:NginxConfigurator
Initialized: <certbot_nginx._internal.configurator.NginxConfigurator object at 0x7f9beb5d59d0>
Prep: True
Single candidate plugin: * webroot
Description: Place files in webroot directory
Entry point: webroot = certbot._internal.plugins.webroot:Authenticator
Initialized: <certbot._internal.plugins.webroot.Authenticator object at 0x7f9be7c58c50>
Prep: True
Selected authenticator <certbot._internal.plugins.webroot.Authenticator object at 0x7f9be7c58c50> and installer <certbot_nginx._internal.configurator.NginxConfigurator object at 0x7f9beb5d59d0>
Plugins selected: Authenticator webroot, Installer nginx
Picked account: <Account(RegistrationResource(body=Registration(status=None, terms_of_service_agreed=None, agreement=None, only_return_existing=None, contact=(), key=None, external_account_binding=None), uri=u’https://acme-staging-v02.api.letsencrypt.org/acme/acct/8733218’, new_authzr_uri=None, terms_of_service=None), 10bfd4fb9fa002a2e85602fd90e594a7, Meta(creation_host=u’cdn01.eplus.net’, creation_dt=datetime.datetime(2019, 3, 28, 13, 42, 18, tzinfo=)))>
Sending GET request to https://acme-staging-v02.api.letsencrypt.org/directory.
Starting new HTTPS connection (1): acme-staging-v02.api.letsencrypt.org:443
https://acme-staging-v02.api.letsencrypt.org:443 “GET /directory HTTP/1.1” 200 724
Received response:
HTTP 200
Server: nginx
Date: Sat, 14 Mar 2020 07:04:48 GMT
Content-Length: 724
X-Frame-Options: DENY
“QVwa5Aw9Yrk”: “Adding random entries to the directory”,
“keyChange”: “https://acme-staging-v02.api.letsencrypt.org/acme/key-change”,
“meta”: {
“caaIdentities”: [
letsencrypt.org
“termsOfService”: “https://letsencrypt.org/documents/LE-SA-v1.2-November-15-2017.pdf”,
“website”: “https://letsencrypt.org/docs/staging-environment/
“newAccount”: “https://acme-staging-v02.api.letsencrypt.org/acme/new-acct”,
“newNonce”: “https://acme-staging-v02.api.letsencrypt.org/acme/new-nonce”,
“newOrder”: “https://acme-staging-v02.api.letsencrypt.org/acme/new-order”,
“revokeCert”: “https://acme-staging-v02.api.letsencrypt.org/acme/revoke-cert
Requesting fresh nonce
Sending HEAD request to https://acme-staging-v02.api.letsencrypt.org/acme/new-nonce.
https://acme-staging-v02.api.letsencrypt.org:443 “HEAD /acme/new-nonce HTTP/1.1” 200 0
Received response:
HTTP 200
Server: nginx
Link: https://acme-staging-v02.api.letsencrypt.org/directory;rel=“index”
Replay-Nonce: 0001ZP_DBhh6aJFGwbCc7tJEZgZgHUYZV4K4vdDsRT1zl9Y
Storing nonce: 0001ZP_DBhh6aJFGwbCc7tJEZgZgHUYZV4K4vdDsRT1zl9Y
JWS payload:
“identifiers”: [
“type”: “dns”,
“value”: “abr.eplus.net
Sending POST request to https://acme-staging-v02.api.letsencrypt.org/acme/new-order:
“protected”: “eyJub25jZSI6ICIwMDAxWlBfREJoaDZhSkZHd2JDYzd0SkVaZ1pnSFVZWlY0SzR2ZERzUlQxemw5WSIsICJ1cmwiOiAiaHR0cHM6Ly9hY21lLXN0YWdpbmctdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9uZXctb3JkZXIiLCAia2lkIjogImh0dHBzOi8vYWNtZS1zdGFnaW5nLXYwMi5hcGkubGV0c2VuY3J5cHQub3JnL2FjbWUvYWNjdC84NzMzMjE4IiwgImFsZyI6ICJSUzI1NiJ9”,
“payload”: “ewogICJpZGVudGlmaWVycyI6IFsKICAgIHsKICAgICAgInR5cGUiOiAiZG5zIiwgCiAgICAgICJ2YWx1ZSI6ICJhYnIuZXBsdXMubmV0IgogICAgfQogIF0KfQ”,
“signature”: “WgQfM9uKbI9qmMIAL7jrXtPwiGn8R45lm-MBWWSJUodwAolqFwKgXB0ISeFJyv0lIQcCqvqhEr_2QPMRQOo8BMouGVvoELuKQZUTOfCBgn2vO4cI4YbulQsUwSJjn29iUjf6Rcx1xXkDfFSW4_a6hUwNfPCdM8b0t14VZmCnE5MWvRlwY1DI60aKYua0XeQAhSIFQ8t2n19AuXN1Y7iwmOJiYXr3sjg0I4aAPzQVzpMqaoUp69YM4BunJUNNU57aF3ZV4t2GB8tSwfVAHQEGVD7uzJ3T2tVjgZiORTjpZgfut_6eKVrIdcfEN8M4xJcws8XEs4R1jgBZM7w-7qlAig”
https://acme-staging-v02.api.letsencrypt.org:443 “POST /acme/new-order HTTP/1.1” 201 354
Received response:
HTTP 201
Server: nginx
Content-Length: 354
Boulder-Requester: 8733218
Location: https://acme-staging-v02.api.letsencrypt.org/acme/order/8733218/79287955
Replay-Nonce: 00016JO6TnWl_63P8gyplJYdzjNE0nlqKaXS5Sdd682ZIcY
“status”: “pending”,
“expires”: “2020-03-21T07:04:48.449009255Z”,
“identifiers”: [
“type”: “dns”,
“authorizations”: [
https://acme-staging-v02.api.letsencrypt.org/acme/authz-v3/43664656
“finalize”: “https://acme-staging-v02.api.letsencrypt.org/acme/finalize/8733218/79287955
Storing nonce: 00016JO6TnWl_63P8gyplJYdzjNE0nlqKaXS5Sdd682ZIcY
JWS payload:
Sending POST request to https://acme-staging-v02.api.letsencrypt.org/acme/authz-v3/43664656:
“protected”: “eyJub25jZSI6ICIwMDAxNkpPNlRuV2xfNjNQOGd5cGxKWWR6ak5FMG5scUthWFM1U2RkNjgyWkljWSIsICJ1cmwiOiAiaHR0cHM6Ly9hY21lLXN0YWdpbmctdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9hdXRoei12My80MzY2NDY1NiIsICJraWQiOiAiaHR0cHM6Ly9hY21lLXN0YWdpbmctdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9hY2N0Lzg3MzMyMTgiLCAiYWxnIjogIlJTMjU2In0”,
“payload”: “”,
“signature”: “Zzs6QxQ76FcudJp25JyeuHvOsx1q0DPa-tXg1B7yV6H-ozZUU11G5o4Y1QsaO4aKjQ9-Ichf63UBBXER9llWB5O_bbt5wD6GH6rG_pthpYVLAh3eh9qRerYt1NNY4rdvnQ79EoN1jw3XtMBbxN–QmRXi2xbwDgl72L9ieOHlS7-389VsV2r57Zlm59USSdthOWSTrGRyRE1eMVBYrL3A0p1EYCX5NwapYO3C1ttQ39-wCiAE9TwfaJZ4k33RCGkCNp2UEKkeZkcX64sNetkKkIpfnOD3_Ne2J-LmwQjXrsYlWiEUKJ0iywJHnXJ1BevIcPjbMEEnwqtPfMKwErh7w”
https://acme-staging-v02.api.letsencrypt.org:443 “POST /acme/authz-v3/43664656 HTTP/1.1” 200 809
Received response:
HTTP 200
Server: nginx
Content-Length: 809
Replay-Nonce: 000156rVQYQj5Qrejqak39JGeguzOoqGaPbGWUb6V4lEd2I
“identifier”: {
“type”: “dns”,
“expires”: “2020-03-21T07:04:48Z”,
“challenges”: [
“type”: “http-01”,
“url”: “https://acme-staging-v02.api.letsencrypt.org/acme/chall-v3/43664656/LD6r_Q”,
“token”: “JpYqjNutM2pvVdx6mOlKbOZY23gB836xbXjKZF_nkpM”
“type”: “dns-01”,
“url”: “https://acme-staging-v02.api.letsencrypt.org/acme/chall-v3/43664656/mdtPuA”,
“type”: “tls-alpn-01”,
“url”: “https://acme-staging-v02.api.letsencrypt.org/acme/chall-v3/43664656/czmHQA”,
Storing nonce: 000156rVQYQj5Qrejqak39JGeguzOoqGaPbGWUb6V4lEd2I
http-01 challenge for abr.eplus.net
Using the webroot path /usr/share/nginx/html for all unmatched domains.
Creating root challenges validation dir at /usr/share/nginx/html/.well-known/acme-challenge
Attempting to save validation to /usr/share/nginx/html/.well-known/acme-challenge/JpYqjNutM2pvVdx6mOlKbOZY23gB836xbXjKZF_nkpM
Waiting for verification…
Challenges loaded. Press continue to submit to CA. Pass “-v” for more info about
challenges.
JWS payload:
“type”: “http-01”,
“resource”: “challenge”
Sending POST request to https://acme-staging-v02.api.letsencrypt.org/acme/chall-v3/43664656/LD6r_Q:
“protected”: “eyJub25jZSI6ICIwMDAxNTZyVlFZUWo1UXJlanFhazM5SkdlZ3V6T29xR2FQYkdXVWI2VjRsRWQySSIsICJ1cmwiOiAiaHR0cHM6Ly9hY21lLXN0YWdpbmctdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9jaGFsbC12My80MzY2NDY1Ni9MRDZyX1EiLCAia2lkIjogImh0dHBzOi8vYWNtZS1zdGFnaW5nLXYwMi5hcGkubGV0c2VuY3J5cHQub3JnL2FjbWUvYWNjdC84NzMzMjE4IiwgImFsZyI6ICJSUzI1NiJ9”,
“payload”: “ewogICJ0eXBlIjogImh0dHAtMDEiLCAKICAicmVzb3VyY2UiOiAiY2hhbGxlbmdlIgp9”,
“signature”: “KwHEKV1MHZE9es3KPkItmxmN_rY-BQDqHVS54SbfEVgJgcdJuICySJjsUuUVSMFu1N9wWOqjnoi0QRBLwruvBse0gGXBzXjKVWGgKff4pgj1695GgqsItAZNEAfBEu6ZAtfeXpSPd2j0YjUoYLgBbaB5-90Bmlui_P9acvL9XPueoAxIei_0CS_hHRQUUiTj6hWPhg2Xa8Ct4wWeAQUom6Fyfp_RMEAjpKxz5e1tbsA6yeWEK8mNa8V67-E0ZMBzHcZmHi9WmveUHlSa-hovGBfsN0FKwiETzxagpDaAhbjyg3IvKLUxdSu7frVQuHND09xjFPo266BUgj9XU9rLRg”
https://acme-staging-v02.api.letsencrypt.org:443 “POST /acme/chall-v3/43664656/LD6r_Q HTTP/1.1” 200 191
Received response:
HTTP 200
Server: nginx
Content-Length: 191
Link: https://acme-staging-v02.api.letsencrypt.org/directory;rel=“index”, https://acme-staging-v02.api.letsencrypt.org/acme/authz-v3/43664656;rel=“up”
Location: https://acme-staging-v02.api.letsencrypt.org/acme/chall-v3/43664656/LD6r_Q
Replay-Nonce: 0002xw-OO3pScYaKcllGQZyLAbiqKshv44iV2W2UNT0H1Ms
“type”: “http-01”,
Storing nonce: 0002xw-OO3pScYaKcllGQZyLAbiqKshv44iV2W2UNT0H1Ms
JWS payload:
“protected”: “eyJub25jZSI6ICIwMDAyeHctT08zcFNjWWFLY2xsR1FaeUxBYmlxS3NodjQ0aVYyVzJVTlQwSDFNcyIsICJ1cmwiOiAiaHR0cHM6Ly9hY21lLXN0YWdpbmctdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9hdXRoei12My80MzY2NDY1NiIsICJraWQiOiAiaHR0cHM6Ly9hY21lLXN0YWdpbmctdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9hY2N0Lzg3MzMyMTgiLCAiYWxnIjogIlJTMjU2In0”,
“payload”: “”,
“signature”: “IylRDR2Gt1hE3gLe96-m7-19yiYIYTceSm3z9-j26-iaGgCcXzsbL7RTzXjnRfFZWP4sf2N8zxmKxKgvLeXQ-RvbuW0Om6rRfpB4ZPoBs_LjnIs18ysCvXEbQdRgwdb7IrUHXzRSKNnJHoeippCDCmp-scN1YZimrdswbzZEXs3dVFOWsuafyNu41wWyS5wvAx34dT_wVfLkecMQlCX-2L65aDsN0nsEjU3Dp7h5qWyGlR1KMSsKTrqnpgPi-u-Zsib4bmpxvZRm5eDWM6oqEPVM7fzWu9P247LDNcjocRav7AxpS_VbswomL7qYaPrbjj6de0-9RoGyVaB32qzVBg”
Received response:
HTTP 200
Server: nginx
Date: Sat, 14 Mar 2020 07:04:49 GMT
Content-Length: 809
Replay-Nonce: 00023BwXConnqh3lEaL3uxZdk2twRd35lt9DdQ_AGM1IiV8
“identifier”: {
“type”: “dns”,
“challenges”: [
“type”: “http-01”,
“type”: “dns-01”,
Storing nonce: 00023BwXConnqh3lEaL3uxZdk2twRd35lt9DdQ_AGM1IiV8
JWS payload:
“protected”: “eyJub25jZSI6ICIwMDAyM0J3WENvbm5xaDNsRWFMM3V4WmRrMnR3UmQzNWx0OURkUV9BR00xSWlWOCIsICJ1cmwiOiAiaHR0cHM6Ly9hY21lLXN0YWdpbmctdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9hdXRoei12My80MzY2NDY1NiIsICJraWQiOiAiaHR0cHM6Ly9hY21lLXN0YWdpbmctdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9hY2N0Lzg3MzMyMTgiLCAiYWxnIjogIlJTMjU2In0”,
“payload”: “”,
“signature”: “cRdj43uQmSE28ZxrSf1Slxww-U86-0Gk6eQsOrRabY2jsbwlMV0SLZIaUHe_gBZaakK0A57yNW2LKS5DI4el8dBM7LllUcstCsMszLj4fr9bGkBTiy4Ye6dQoXha8ZMRUyS17OcTT0owDpuM2oHaNZ3jEExHtPj036ncF-4212k4Nur00fH5OvrTTMOOdpbng_yMEDkC9y0-gVafZs7689rgARM8uAvQeOqRC2MtDrnVIlmDDX8UDgoLx2yCH_LtK343a7Cx9hulqCqtqhtpB0r0znqTNs4IEhCIBedLO4XtXBCNr-1kPh0fWFaihB6qhTy8ZnASchUva4EbloqAwg”
Received response:
HTTP 200
Server: nginx
Date: Sat, 14 Mar 2020 07:04:52 GMT
Content-Length: 809
Replay-Nonce: 0002bbwrrlQzRL038BsrDM2xYgjMARPhoPzpP2neIw1mcEE
“identifier”: {
“type”: “dns”,
“challenges”: [
“type”: “http-01”,
“type”: “dns-01”,
Storing nonce: 0002bbwrrlQzRL038BsrDM2xYgjMARPhoPzpP2neIw1mcEE
JWS payload:
“protected”: “eyJub25jZSI6ICIwMDAyYmJ3cnJsUXpSTDAzOEJzckRNMnhZZ2pNQVJQaG9QenBQMm5lSXcxbWNFRSIsICJ1cmwiOiAiaHR0cHM6Ly9hY21lLXN0YWdpbmctdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9hdXRoei12My80MzY2NDY1NiIsICJraWQiOiAiaHR0cHM6Ly9hY21lLXN0YWdpbmctdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9hY2N0Lzg3MzMyMTgiLCAiYWxnIjogIlJTMjU2In0”,
“payload”: “”,
“signature”: “iwjcVvPy-TleKuNHBBr5WMesjTWQI3t_f8eAstnOI_4SHOSVh8STbJLvKMnXdgu4_nRdEjJd5wnexswkvjfzPy0NCJVQAlJybZ8Xh2j08fhfDk-wMUP0u5U9zljB6QXVzKQaRD5Or-FlG3JGHr5RThqk11CeeT_OqLNK_tUr-ZyqKGHqbUvnJpntU29piTUEGYKQ2245WqVAH6HYpdp94xcAOzTAk201DPvSP6S9N2T7SIdACU77SRNo4V8s2Bgn1RAtmfKsTBX6N7yB5I5FBFB_2e0YHGAx_FfhrnSYTQH1qdUEeu4M8Mc9uxjtuEjyZErpZQ7N_sAFaWOAcUty8A”
Received response:
HTTP 200
Server: nginx
Date: Sat, 14 Mar 2020 07:04:55 GMT
Content-Length: 809
Replay-Nonce: 0002z7R0ZJBGnqe0D6lnBfFN_HGseUyM1rPILqdfzM6LIww
“identifier”: {
“type”: “dns”,
“challenges”: [
“type”: “http-01”,
“type”: “dns-01”,
Storing nonce: 0002z7R0ZJBGnqe0D6lnBfFN_HGseUyM1rPILqdfzM6LIww
JWS payload:
“protected”: “eyJub25jZSI6ICIwMDAyejdSMFpKQkducWUwRDZsbkJmRk5fSEdzZVV5TTFyUElMcWRmek02TEl3dyIsICJ1cmwiOiAiaHR0cHM6Ly9hY21lLXN0YWdpbmctdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9hdXRoei12My80MzY2NDY1NiIsICJraWQiOiAiaHR0cHM6Ly9hY21lLXN0YWdpbmctdjAyLmFwaS5sZXRzZW5jcnlwdC5vcmcvYWNtZS9hY2N0Lzg3MzMyMTgiLCAiYWxnIjogIlJTMjU2In0”,
“payload”: “”,
“signature”: “AfOIvEO_ztlMJbo0KB_ikqaD0Mu0m0NYy9D9Ykmq4W60t0TZLLVjpr0Z6Im0S535zka73AeZXNsW4OOSW_Si2sXXCLgxTE0aPOWZCh7JGccYJ9r87J-cpcb1ia_oP5FszT2npOVgKNbiWI14nF1nYBJvACtrQLeB4LcXDz-17rrEc-lmta2bYojgjPVo-1LpBxpGpDSy_VYfbYLz9OdknDeAvEz_qxMbiHwVWT8rAvJEIWytWtzZj-SHlKDLGVrEtBeNmP29Fp144P0h2KDR4GXz-vS30l4T-2xc005_xu5kV5iH1MM8qujlWMazQmB2JfB5QfeV7hFc2W0ugBey_A”
https://acme-staging-v02.api.letsencrypt.org:443 “POST /acme/authz-v3/43664656 HTTP/1.1” 200 1025
Received response:
HTTP 200
Server: nginx
Date: Sat, 14 Mar 2020 07:04:58 GMT
Content-Length: 1025
Replay-Nonce: 0002nsi-igJ-u2fOOw-eY_NcJFW1wESHnMTGQeG2DTVZw00
“identifier”: {
“type”: “dns”,
“status”: “invalid”,
“challenges”: [
“type”: “http-01”,
“error”: {
“type”: “urn:ietf:params:acme:error:connection”,
“detail”: “During secondary validation: Fetching http://abr.eplus.net/.well-known/acme-challenge/JpYqjNutM2pvVdx6mOlKbOZY23gB836xbXjKZF_nkpM: Timeout during connect (likely firewall problem)”,
“status”: 400
“token”: “JpYqjNutM2pvVdx6mOlKbOZY23gB836xbXjKZF_nkpM”,
“validationRecord”: [
“url”: “http://abr.eplus.net/.well-known/acme-challenge/JpYqjNutM2pvVdx6mOlKbOZY23gB836xbXjKZF_nkpM”,
“hostname”: “abr.eplus.net”,
“port”: “80”,
“addressesResolved”: [
“50.93.182.138”
“addressUsed”: “50.93.182.138”
Storing nonce: 0002nsi-igJ-u2fOOw-eY_NcJFW1wESHnMTGQeG2DTVZw00
Challenge failed for domain abr.eplus.net
Reporting to user: The following errors were reported by the server:
Type: connection
Detail: During secondary validation: Fetching http://abr.eplus.net/.well-known/acme-challenge/JpYqjNutM2pvVdx6mOlKbOZY23gB836xbXjKZF_nkpM: Timeout during connect (likely firewall problem)
To fix these errors, please make sure that your domain name was entered correctly and the DNS A/AAAA record(s) for that domain contain(s) the right IP address. Additionally, please check that your computer has a publicly routable IP address and that no firewalls are preventing the server from communicating with the client. If you’re using the webroot plugin, you should also verify that you are serving files from the webroot path you provided.
Encountered exception:
File “/opt/eff.org/certbot/venv/lib/python2.7/site-packages/certbot/_internal/auth_handler.py”, line 91, in handle_authorizations
File “/opt/eff.org/certbot/venv/lib/python2.7/site-packages/certbot/_internal/auth_handler.py”, line 180, in _poll_authorizations
raise errors.AuthorizationError(‘Some challenges have failed.’)
AuthorizationError: Some challenges have failed.
Calling registered functions
Removing /usr/share/nginx/html/.well-known/acme-challenge/JpYqjNutM2pvVdx6mOlKbOZY23gB836xbXjKZF_nkpM
All challenges cleaned up
Attempting to renew cert (abr.eplus.net) from /etc/letsencrypt/renewal/abr.eplus.net.conf produced an unexpected error: Some challenges have failed… Skipping.
Traceback was:
File “/opt/eff.org/certbot/venv/lib/python2.7/site-packages/certbot/_internal/renewal.py”, line 448, in handle_renewal_request
main.renew_cert(lineage_config, plugins, renewal_candidate)
File “/opt/eff.org/certbot/venv/lib/python2.7/site-packages/certbot/_internal/main.py”, line 1176, in renew_cert
renewed_lineage = _get_and_save_cert(le_client, config, lineage=lineage)
File “/opt/eff.org/certbot/venv/lib/python2.7/site-packages/certbot/_internal/main.py”, line 116, in _get_and_save_cert
renewal.renew_cert(config, domains, le_client, lineage)
File “/opt/eff.org/certbot/venv/lib/python2.7/site-packages/certbot/_internal/renewal.py”, line 306, in renew_cert
new_cert, new_chain, new_key, _ = le_client.obtain_certificate(domains, new_key)
File “/opt/eff.org/certbot/venv/lib/python2.7/site-packages/certbot/_internal/client.py”, line 344, in obtain_certificate
File “/opt/eff.org/certbot/venv/lib/python2.7/site-packages/certbot/_internal/client.py”, line 391, in _get_order_and_authorizations
authzr = self.auth_handler.handle_authorizations(orderr, best_effort)
/etc/letsencrypt/live/abr.eplus.net/fullchain.pem (failure)
Exiting abnormally:
File “/opt/eff.org/certbot/venv/bin/letsencrypt”, line 11, in
sys.exit(main())
File “/opt/eff.org/certbot/venv/lib/python2.7/site-packages/certbot/main.py”, line 15, in main
File “/opt/eff.org/certbot/venv/lib/python2.7/site-packages/certbot/_internal/main.py”, line 1347, in main
File “/opt/eff.org/certbot/venv/lib/python2.7/site-packages/certbot/_internal/main.py”, line 1255, in renew
renewal.handle_renewal_request(config)
File “/opt/eff.org/certbot/venv/lib/python2.7/site-packages/certbot/_internal/renewal.py”, line 473, in handle_renewal_request
len(renew_failures), len(parse_failures)))
Error: 1 renew failure(s), 0 parse failure(s)
    Type: connection
nginx -v
nginx version: nginx/1.17.6 (nginx-plus-r20)
cat /etc/redhat-release
CentOS Linux release 7.6.1810 (Core)
Yes
no
./certbot-auto --version
certbot 1.3.0
I don’t understand why I am getting the following error:
Type: connection
I can see 200 when requesting validation:
66.133.109.36 - - [14/Mar/2020:03:04:49 -0400] “GET /.well-known/acme-challenge/JpYqjNutM2pvVdx6mOlKbOZY23gB836xbXjKZF_nkpM HTTP/1.1” 200 87 “-” “Mozilla/5.0 (compatible; Let’s Encrypt validation server; +https://www.letsencrypt.org)” "-“rid=“39c0e004c2b934fa2a4b25cbc4f10be7” pck=“http://-/.well-known/acme-challenge/JpYqjNutM2pvVdx6mOlKbOZY23gB836xbXjKZF_nkpM"ucs=”-”
85.215.2.227 - - [14/Mar/2020:03:09:34 -0400] “GET /.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de HTTP/1.1” 404 153 “-” “Server-Daten Check your Website (https://check-your-website.server-daten.de/)” "-“rid=“d9772f4788f0152d2bfddd02be4083f9” pck=“http://-/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de"ucs=”-”
172.104.24.29 - - [14/Mar/2020:03:10:24 -0400] “GET /.well-known/acme-challenge/letsdebug-test HTTP/1.1” 404 153 “-” “Mozilla/5.0 (compatible; Let’s Debug emulating Let’s Encrypt validation server; +https://letsdebug.net)” "-“rid=“cde9c7a16553c0380c89d470fb1a5188” pck=“http://-/.well-known/acme-challenge/letsdebug-test"ucs=”-”
66.133.109.36 - - [14/Mar/2020:03:10:25 -0400] “GET /.well-known/acme-challenge/xCuqtSq4Jsxvtyypc_bOdZrFvcJEBfAvpzwi7PbMJwc HTTP/1.1” 404 153 “-” “Mozilla/5.0 (compatible; Let’s Encrypt validation server; +https://www.letsencrypt.org)” "-“rid=“7b96dbd9cf09411a98e4b7766518ac53” pck=“http://-/.well-known/acme-challenge/xCuqtSq4Jsxvtyypc_bOdZrFvcJEBfAvpzwi7PbMJwc"ucs=”-”
I can also see the server is up and valid:
https://letsdebug.net/abr.eplus.net/112434
cat renewal/abr.eplus.net.conf
renew_before_expiry = 30 days
version = 0.29.1
archive_dir = /etc/letsencrypt/archive/abr.eplus.net
cert = /etc/letsencrypt/live/abr.eplus.net/cert.pem
privkey = /etc/letsencrypt/live/abr.eplus.net/privkey.pem
chain = /etc/letsencrypt/live/abr.eplus.net/chain.pem
fullchain = /etc/letsencrypt/live/abr.eplus.net/fullchain.pem
[renewalparams]
authenticator = webroot
installer = nginx
account = e1e57b550cc02e1ac7385817fd1a4c1c
webroot_path = /usr/share/nginx/html,
[[webroot_map]]
abr.eplus.net = /usr/share/nginx/html
I think it's related to more strict policy
can only see hits from one IP address, should see 3 other request
You’re right.
Are you blocking AWS? I can’t access http://abr.eplus.net/ from an AWS region where one of Let’s Encrypt’s validation servers is.
It’s more related to AWS direct connect and with asyn routing across the box.
I have submitted an exception:
Will have this fixed after we move over to Azure express route which will happen with 20days
When will I know if this site will be added to exception?
