Can not renew a cert with certbot: Timeout during connect (likely firewall problem)
My cert is due to renewal. I am running certbot renew and this is the result that I get. Please advise!
Processing /etc/letsencrypt/renewal/myrgorod.net.conf
tls-sni-01 challenge for myrgorod.net
tls-sni-01 challenge for www.myrgorod.net
Attempting to renew cert (myrgorod.net) from /etc/letsencrypt/renewal/myrgorod.net.conf produced an unexpected error: Failed authorization procedure. myrgorod.net (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Timeout during connect (likely firewall problem). Skipping.
  /etc/letsencrypt/live/myrgorod.net/fullchain.pem (failure)
   Domain: myrgorod.net
   Type:   connection
   Detail: Timeout during connect (likely firewall problem)
Hi @danielrychel,
myrgorod.net domain points to ip 162.255.119.189 and if you try to connect to this domain (port 80) it is finally redirected to https://www.myrgorod.net (ip 45.55.214.89).
The problem here is that you are using tls-sni-01 challenge so LE will try to connect to https://myrgorod.net to resolve the challenge but you are not serving anything on port 443 (or you are blocking it) for domain myrgorod.net.
So, as an advice, as tls-sni-01 challenge is deprecated you could try http challenge as it should work fine with your current conf:
certbot renew --preferred-challenges http
Above command will or won’t work depending on how you issued your certificates in first place.
If you want to test, first, made a backup of /etc/letsencrypt/ and the conf for your web server just in case ;).
Good luck,
sahsanu
Thank you! That wad very helpful!
