I experience the same problem as in this post:
Version: certbot 0.31.0
When running: sudo certbot renew --dry-run
I get:
Processing /etc/letsencrypt/renewal/shufflemix.com.conf
http-01 challenge for shufflemix.com
http-01 challenge for shufflemix.de
http-01 challenge for shufflemix.nl
http-01 challenge for www.shufflemix.com
http-01 challenge for www.shufflemix.de
http-01 challenge for www.shufflemix.nl
Attempting to renew cert (shufflemix.com) from /etc/letsencrypt/renewal/shufflemix.com.conf produced an unexpected error: Failed authorization procedure. www.shufflemix.de (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching https://www.shufflemix.de/.well-known/acme-challenge/3cg2dKI85X-eJr7EGVMxELKYtCj5MeD5tTa5EQ13fC4: Error getting validation data. Skipping.
/etc/letsencrypt/live/shufflemix.com/fullchain.pem (failure)
    Domain: www.shufflemix.de
    Type: connection
    Detail: Fetching
Timeout during connect (likely firewall problem) Is the main problem. But All domains are ok. No firewall applied. Using Fail2ban.
How to deal with this. Since the certs need to be renewed by tomorrow (its a clients site).
Are you getting any "Timeout during connect" errors? The error in your post is something else.
"Error getting validation data" is a bit of a generic error message -- it can happen for multiple reasons (though I can only think of one right now).
For me, connecting to http://www.shufflemix.de/ over IPv6 times out.
Connecting to https://www.shufflemix.de/ over IPv6 gets a "No route to host" error.
Are you sure the IP address in your DNS records, network configuration and firewall settings are correct?
The CA software can fall back to IPv4 in some circumstances, but not always. You need to fix your site.
When running again: sudo certbot renew --dry-run
I get the same result saying the .nl is the problem? Attempting to renew cert (shufflemix.com) from /etc/letsencrypt/renewal/shufflemix.com.conf produced an unexpected error: Failed authorization procedure. www.shufflemix.nl (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching https://www.shufflemix.nl/.well-known/acme-challenge/RL-PV-iOBcWpmrTJsOBJBVNU2FnlwPSO3gvcYFQugNo: Error getting validation data. Skipping.
I will have a look at the DNS settings again. But seems a bit strange to me, that after just a few months when I first generated the certs the IPv6 is causing this? I know I added an AAA record for all the domains.
I referred to the other topic since there also was this “behaviour of random domain” giving the error.
Something probably changed since you last validated the names.
If you added the IPv6 IP to your DNS after last time, that would explain it, of course.
Or if your IPv6 connectivity was working before and only broke recently.
If the website didn't used to redirect to HTTPS, that could explain it. Redirecting to HTTPS is fine, but redirecting to a broken destination won't validate reliably, if at all. Let's Encrypt will try to work around some issues for the first request, but less so -- or not at all? -- for subsequent requests. (Also, I don't think there's any fallback attempt for "no route to host" errors.)
