Timeout during connect with certbot renewal
Since this month my let’s encrypt certificate for my domain is not renewing anymore. As far as I know i did not change anything. What I DID do this month is restore my entire webserver from a snapshot after I got a corrupted disk, the snapshot was about a week old.
I ran a check on https://check-your-website.server-daten.de/?q=home.mecallie.com and that seems fine to me, except for one error at the bottom…
I have checked my firewall: port 80 seems to be forwarded ok.
home.mecallie.com
certbot renew --dry-run
Processing /etc/letsencrypt/renewal/home.mecallie.com.conf
http-01 challenge for home.mecallie.com
Attempting to renew cert (home.mecallie.com) from /etc/letsencrypt/renewal/home.mecallie.com.conf produced an unexpected error: Failed authorization procedure. home.mecallie.com (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://home.mecallie.com/.well-known/acme-challenge/h7EsR5ii1R-iGpjfky2_TdIPRWPCR0aRI6uJP0Dl4cU: Timeout during connect (likely firewall problem). Skipping.
  /etc/letsencrypt/live/home.mecallie.com/fullchain.pem (failure)
**          (The test certificates below have not been saved.)
**          (The test certificates above have not been saved.)
   Domain: home.mecallie.com
   Type:   connection
   Detail: Fetching
nginx 1.14.0
Ubuntu 18.04.4 LTS
N/A
no
0.27.0 EDIT: just upgraded to certbot 0.31.0 via ppa. Same issue.
Hi @Mecallie
there is nothing ok. Grade T - Timeout. And an explicit warning.
http://home.mecallie.com/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 217.122.13.60
	-14
	Fatal: Check of /.well-known/acme-challenge/random-filename has a timeout.
Creating a Letsencrypt certificate via http-01 challenge
can't work. You need a running webserver (http) and an
open port 80. If it's a home server + ipv4, perhaps a correct
port forwarding port 80 extern ⇒ working port intern is
required. Port 80 / http can  redirect to another domain
port 80 or port 443, but not other ports. If it's a home
server, perhaps your ISP blocks port 80. Then you
may use the dns-01 challenge.
Ah, I actually missed the part below the screenshots. Or it was not ready yet?
Something strange was (is?) going on with my firewall. Port 80 was forwarded just fine (and if I go to port 80 on the domain name in a browser I am redirected to 443 by Nextcloud). However, after deleting the NAT rule and creating it again I now get the following output with cerbot renew --dry-run:
new certificate deployed with reload of nginx server; fullchain is
  /etc/letsencrypt/live/home.mecallie.com/fullchain.pem (success)
The weird thing is that the actual renew still does not work:
Attempting to renew cert (home.mecallie.com) from /etc/letsencrypt/renewal/home.mecallie.com.conf produced an unexpected error: Failed authorization procedure. home.mecallie.com (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://home.mecallie.com/.well-known/acme-challenge/TLd0XbqcfelRRnMt1jkw38qvR4IqKxrcY22w8yyYAbI: Error getting validation data. Skipping.
   Type:   connection
   Detail: Fetching
So the test goes fine now, but the actual renew still does not :?
Use the online tool to recheck your domain and to see the answer.
I did. Am I correct in assuming that the answer is the fact that I get a 403 error instead of a 404?
You have to fix that.
Read
I gathered as much after reading that error. No idea why that starts happening all of a sudden. But does not seem to have anything to do with let’s encrypt but with the nginx/nextcloud config. I will check the Nextcloud forum. Thank you for your assistance.
