Let's Encrypt Renew Certificate Issues
My domain is: www.thechemicalhut.org
I ran this command: sudo certbot renew --dry-run
Processing /etc/letsencrypt/renewal/www.thechemicalhut.org.conf
Starting new HTTPS connection (1): acme-staging-v02.api.letsencrypt.org
http-01 challenge for www.thechemicalhut.org
Waiting for verification…
Attempting to renew cert (www.thechemicalhut.org) from /etc/letsencrypt/renewal/www.thechemicalhut.org.conf produced an unexpected error: Failed authorization procedure. www.thechemicalhut.org (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://www.thechemicalhut.org/.well-known/acme-challenge/dGWtG0y6OgI8dRjapdyjGTEeZfHq8eB0ys6kfRf-pjw: Timeout during connect (likely firewall problem). Skipping.
/etc/letsencrypt/live/www.thechemicalhut.org/fullchain.pem (failure)
    Domain: www.thechemicalhut.org
    Type: connection
    Detail: Fetching
My web server is (include version): nginx/1.15.3
My hosting provider, if applicable, is: digitalocean
It looks like you probably have a firewall installed on your Ubuntu setup.
Try:
ufw allow http
Also check in the DigitalOcean control panel that you haven’t accidentally enabled the firewall without permitting port 80.
Thanks.
Sorted it was the firewall from digitalocean that was the issue.
J
