Problem on certbot dry run
Hi All,
I have a problem on running certbot command when I try to execute the certbot renew --dry-run -v this are the error show
Processing /etc/letsencrypt/renewal/www.example.com.conf
Certificate not due for renewal, but simulating renewal for dry run
Simulating renewal of an existing certificate for www.example.com
http-01 challenge for www.example.com
Challenge failed for domain www.example.com
Domain: www.example.com
Type: connection
Detail: 203.177.XX.XX: Fetching http://www.example.com/.well-known/acme-challenge/C7M-E7UyLfFfPSzkK-ONuW1WD9zS0fscuQ-FUcuuaxQ: Timeout during connect (likely firewall problem)
Failed to renew certificate www.example.com with error: Some challenges have failed.
All simulated renewals failed. The following certificates could not be renewed:
/etc/letsencrypt/live/www.example.com/fullchain.pem (failure)
port 80, 443 is already open on the firewall, can anyone help me to troubleshoot the problem. Thanks
Not enough; it's not reachable from the Internet:
Here is an online tool TCP Port Scanner, Online Port Scan, Port Scanning | IPVoid to do a port scan, it use the IP Address and not the Domain Name.
Also you will want to select Scan all common ports
Thanks @rg305 @Bruce5051
we already solved the problem, by opening port 80 on the appliance firewall
