Hi Team,
My domain uses the Let's Encrypt certificate for SSL communication. I can generate the certificate but I can not able to renew the certificate. I am using apache httpd configuration.
I have explicitly verified the ACME using the below command.
curl -v http://everprint.io/.well-known/acme-challenge/test
curl -v http://myeverbee.io/.well-known/acme-challenge/test
My domain is: everprint.io, www.everprint.io, myeverbee.io, www.myeverbee.io
I ran this command: sudo certbot renew --dry-run -v
letsencrypt.txt (111.4 KB)
Processing /etc/letsencrypt/renewal/everprint.io.conf
Certificate not due for renewal, but simulating renewal for dry run
Simulating renewal of an existing certificate for everprint.io and www.everprint.io
http-01 challenge for everprint.io
http-01 challenge for www.everprint.io
Challenge failed for domain everprint.io
Domain: everprint.io
Type: connection
Detail: 52.9.2.39: Fetching http://everprint.io/.well-known/acme-challenge/KM8sjWVdWRTXjgxEallYGCHMkGhRaeKTSm7Q44GUINw: Timeout during connect (likely firewall problem)
Failed to renew certificate everprint.io with error: Some challenges have failed.
Processing /etc/letsencrypt/renewal/myeverbee.io.conf
Simulating renewal of an existing certificate for myeverbee.io and www.myeverbee.io
http-01 challenge for myeverbee.io
http-01 challenge for www.myeverbee.io
Challenge failed for domain myeverbee.io
Challenge failed for domain www.myeverbee.io
Domain: myeverbee.io
Type: connection
Detail: 52.9.2.39: Fetching http://myeverbee.io/.well-known/acme-challenge/tCPCh5YrrJqpcgkO-eOCys6t2JmiSuQg4_tEo8MMli4: Timeout during connect (likely firewall problem)
Domain: www.myeverbee.io
Type: connection
Detail: 52.9.2.39: Fetching http://www.myeverbee.io/.well-known/acme-challenge/pY9pulLWWRmN2rgJni8EZ2jE-pmfWm7LbqsAOe904rg: Timeout during connect (likely firewall problem)
Failed to renew certificate myeverbee.io with error: Some challenges have failed.
All simulated renewals failed. The following certificates could not be renewed:
/etc/letsencrypt/live/everprint.io/fullchain.pem (failure)
/etc/letsencrypt/live/myeverbee.io/fullchain.pem (failure)
2 renew failure(s), 0 parse failure(s)
My web server is (include version): Apache/2.4.58 (Ubuntu)
The operating system my web server runs on is (include version):Ubuntu 24.04.1 LTS
My hosting provider, if applicable, is: Namecheap
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot):certbot 2.9.0
