My domain is: advanceraven.com
I ran this command: sudo certbot renew --dry-run
Simulating renewal of an existing certificate for advanceraven.com and 4 more domains
Domain: advanceraven.com
Type: connection
Detail: During secondary validation: 71.164.95.180: Fetching http://advanceraven.com/.well-known/acme-challenge/LkTzALHRz0JQfcDK1JQ9-5ppCnoflAjGqAn0LFle3gs: Timeout during connect (likely firewall problem)
Domain: dev.advanceraven.com
Type: connection
Detail: During secondary validation: 71.164.95.180: Fetching http://dev.advanceraven.com/.well-known/acme-challenge/XlhTUrliAzPSTq_DzpCXLkfaJOVWsUhpHiPWM6md920: Timeout during connect (likely firewall problem)
Domain: gov.advanceraven.com
Type: connection
Detail: During secondary validation: 71.164.95.180: Fetching http://gov.advanceraven.com/.well-known/acme-challenge/nm1B4BKHwyEqedPxQp0fKk-rzje7uwOoY0URVjS7SLo: Timeout during connect (likely firewall problem)
Domain: portal.advanceraven.com
Type: connection
Detail: During secondary validation: 71.164.95.180: Fetching http://portal.advanceraven.com/.well-known/acme-challenge/3GQqQ_xMV8sad33M3DuWMCXjVfRGRQl349Oof8tKZVw: Timeout during connect (likely firewall problem)
Domain: www.advanceraven.com
Type: connection
Detail: During secondary validation: 71.164.95.180: Fetching http://www.advanceraven.com/.well-known/acme-challenge/ALqB4ycuofk-iQzLsoD--xL8waOHyvVL80TpAT0YECo: Timeout during connect (likely firewall problem)
Failed to renew certificate advanceraven.com with error: Some challenges have failed.
My web server is (include version): Apache/2.4.52 (Ubuntu)
The operating system my web server runs on is (include version): Ubuntu 22.04.4 LTS
My hosting provider, if applicable, is: Self Hosted
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): N/A
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 2.10.0
I have already looked through various other topics to troubleshoot and am stuck
Port 80 and 443 are indeed open. This has been verified using nmap and telnet.
I have reviewed the firewall rules and nothing is blocking 443 or 80
I have verified the Apache virtual host directives to ensure they are configured properly, all checks out (note this was all working nicely for quite some time until about 2 weeks ago)
The web server is listening on 80 and 443, this was verified using netstat -tunlp | grep 80 & netstat -tunlp | grep 443
I have been using the --apache flag consistently, and just ran several webroot tests without success
I have on another server a manual Lets Encrypt setup that uses DNS ACME Challenge and has zero issue. Am using the --apache flag as this particular server runs about 40 domains, all of which have renewed without issue for years.
I have even utilized the LetsDebug utility to troubleshoot and am running low on ideas.....
I did happen to notice a New order message during a renewal attempt a day ago, so not sure if a limit was hit or if I truly am missing something.....
Any ideas?
