Renewal problem
My domain is: https://www.zecaafonso46.duckdns.org
I ran this command: certbot renew --dry-run
Processing /etc/letsencrypt/renewal/www.zecaafonso46.duckdns.org.conf
http-01 challenge for www.zecaafonso46.duckdns.org
Waiting for verification…
Attempting to renew cert (www.zecaafonso46.duckdns.org) from /etc/letsencrypt/renewal/www.zecaafonso46.duckdns.org.conf produced an unexpected error: Failed authorization procedure. www.zecaafonso46.duckdns.org (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://www.zecaafonso46.duckdns.org/.well-known/acme-challenge/l6Q992x44-UV7Wh2CNmLgvdhaa9Db1UuC7U5cwn32WM: Timeout during connect (likely firewall problem). Skipping.
/etc/letsencrypt/live/www.zecaafonso46.duckdns.org/fullchain.pem (failure)
    Domain: www.zecaafonso46.duckdns.org
    Type: connection
    Detail: Fetching
My web server is (include version): apache2 2.4.25-3+deb9u9
The operating system my web server runs on is (include version): Debian 9.13
My hosting provider, if applicable, is: Own.
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): 0.28.0
Hi @rickiek,
It does look like you have a firewall blocking inbound connections on port 80 on this system, and only allowing port 443. Inbound port 80 connections are required for your certificate renewal. Could you find and change that firewall policy?
Yes, that solved it!
To me it seemed strange that port 80 should be open, seemed natural that only 443 should be open. So I didn’t try it.
Thanks a lot for your fast reply!
Kind Regards,
Rickie
I’m glad it worked for you!
Let’s Encrypt has a document about this
In case you’re curious, the reason that port 80 is required is kind of obscure—when Let’s Encrypt was first created, we planned to also allow renewals on port 443 using substantially the same technology, but it turned out that the way that some large shared hosting providers handled HTTPS would have allowed one shared customer to obtain certificates for another customer’s domain that was hosted on the same server. The equivalent problem mostly didn’t exist for share hosting providers’ implementation of HTTP, so the file-based authentication method using port 80 was preserved while the one using port 443 [“https-01”] was eliminated. There was another method using port 443 [“tls-sni-01”], but this method subsequently turned out to have other somewhat analogous problems with shared hosting environments. This history is described in section 4.3 of https://jhalderm.com/pub/papers/letsencrypt-ccs19.pdf and caused a fair amount of stress for the people behind Let’s Encrypt at the time! … There is a new and more complicated method [“tls-alpn-01”] that once again uses port 443—third time’s the charm!—but it doesn’t work well with Apache, and Certbot’s Apache integration can’t make use of it.
