servmin.duckdns.org
certbot renew --cert-name servmin.duckdns.org --dry-run
It produced this output: Simulating renewal of an existing certificate for servmin.duckdns.org
Domain: servmin.duckdns.org
Type: connection
Detail: Fetching http://servmin.duckdns.org/.well-known/acme-challenge/DafWAZIdHFa7zZGDfBwxM-rsghnCERVLH5V3ik0XOEs: Timeout during connect (likely firewall problem)
Failed to renew certificate servmin.duckdns.org with error: Some challenges have failed.
Server version: Apache/2.4.38 (Debian)
Server built: 2021-06-10T10:13:06
Distributor ID: Debian
Description:Debian GNU/Linux 10 (buster)
Release: 10
Codename: buster
own server
certbot 1.17.0
What can I do about it and what is to be done to make an automatic renewing possible?
thanks for Your attention
jori
