Need help with auto renewing my certificate
My domain is: https://n00bserver.duckdns.org/
I ran this command: sudo certbot renew
Processing /etc/letsencrypt/renewal/n00bserver.duckdns.org.conf
Renewing an existing certificate for n00bserver.duckdns.org
Domain: n00bserver.duckdns.org
Type: connection
Detail: 87.195.250.114: Fetching http://n00bserver.duckdns.org/.well-known/acme-challenge/bcE6vXVeDNPb6lGOERkjub1r_HJDBENuEY6I-PCKywE: Error getting validation data
Failed to renew certificate n00bserver.duckdns.org with error: Some challenges have failed.
/etc/letsencrypt/live/n00bserver.duckdns.org/fullchain.pem (failure)
My web server is (include version): Jellyfin 10.10.4
The operating system my web server runs on is (include version): Ubuntu 24.04.1 LTS
My hosting provider, if applicable, is: DuckDNS
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): Putty?
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.9.0
A Let's Debug test shows an HTTP request (port 80) failing with "No Route to Host". Yet, HTTPS requests (port 443) work fine.
This is probably a port-forwarding or NAT problem in your router or local network. Make sure HTTP requests on port 80 reach the same machine you run Certbot on.
Yup I opened port 80 and I can renew it again, thanks!
