Timeout during connect (likely firewall problem) | port 80 is opened
I wanted to renew my certificates for my website but I cant seem to do it and it is expiring soon :confused: .
My domain is: faruse.com
I ran this command:sudo certbot renew --dry-run
    Processing /etc/letsencrypt/renewal/faruse.com.conf
    http-01 challenge for faruse.com
    http-01 challenge for www.faruse.com
    Challenge failed for domain faruse.com
    Challenge failed for domain www.faruse.com
    Attempting to renew cert (faruse.com) from /etc/letsencrypt/renewal/faruse.com.conf produced an unexpected error: Some challenges have failed.. Skipping.
      /etc/letsencrypt/live/faruse.com/fullchain.pem (failure)
    **          (The test certificates below have not been saved.)
    **          (The test certificates above have not been saved.)
       Domain: faruse.com
       Type:   connection
       Detail: Fetching
       https://faruse.com/.well-known/acme-challenge/RnMkdZ5vu44QA4Xu_x0dqhXjQnfNhIiviK8QRfTbhBE:
       Domain: www.faruse.com
       Type:   connection
       Detail: Fetching
       https://www.faruse.com/.well-known/acme-challenge/r5_ueYajWrZDNtmBgXFzijdnJggDzCgKte5rw1Cn-dc:
My web server is (include version): nginx 1.18 with Nodejs + express in port 5000
The operating system my web server runs on is (include version): Ubuntu 20.04
My hosting provider, if applicable, is: Cloudflare
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 0.40.0
I have been reading and it seems like most says that it is because my port 80 is not open, but when I run : sudo netstat -ntlp | grep LISTEN
I get this :
tcp        0      0 127.0.0.1:33060         0.0.0.0:*               LISTEN      1061232/mysqld
tcp        0      0 127.0.0.1:3306          0.0.0.0:*               LISTEN      1061232/mysqld
tcp        0      0 0.0.0.0:80              0.0.0.0:*               LISTEN      2732734/nginx: mast
tcp        0      0 127.0.0.53:53           0.0.0.0:*               LISTEN      600/systemd-resolve
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      1971950/sshd: /usr/
tcp        0      0 0.0.0.0:7000            0.0.0.0:*               LISTEN      2407557/python3
tcp        0      0 0.0.0.0:443             0.0.0.0:*               LISTEN      2732734/nginx: mast
tcp6       0      0 :::5000                 :::*                    LISTEN      2407862/node /root/
tcp6       0      0 :::80                   :::*                    LISTEN      2732734/nginx: mast
tcp6       0      0 :::22                   :::*                    LISTEN      1971950/sshd: /usr/
tcp6       0      0 :::443                  :::*                    LISTEN      2732734/nginx: mast
So I am not sure what am i doing wrong, any help will be appreciated.
Thanks in advance.
I couldn't find any issues regarding why your web server doesn't work (beside Maybe Cloudflare blocked those requests?). But since you are using Cloudflare, the best way to solve this is to utilize Cloudflare's DNS API with certbot Cloudflare plugin.
You can obtain the plugin via SNAP, the instructions are available on certbot.eff.org
Hi @Nicholas
first, your configuration is buggy. If you use --nginx, a temporary rule is added, so https is never checked. But your result says, that https is checked.
Second: I can open your https url. If Letsencrypt can't, you have a regional blocking firewall.
PS: If you use Cloudflare, Cloudflare redirects to https -> use webroot, not --nginx.
Hi @stevenzhu , Thankyou for your response, I will try snaps for now, but will not clash with the existing configurations of certbot? Thanks
It's always better if you backup your /etc/letsencrypt/ folder before you do the upgrade or switch.
Also, (After backup) You can uninstall your certbot and get it via snap, since it provides more support to certbot (more plugins etc).
Hi @JuergenAuer , Thankyou for your response,
I see, how should I fix this in the nginx server block ?
Hmmm okay, How can i unblock this regional blocking firewall ? I tried to renew with webroot, but it told me to insert my webroot, where as i believe my files are handled by connecting to a port and not from a directory.
here is my nginx server blocks:
	root /var/www/html;
	server_name faruse.com www.faruse.com;
		proxy_pass http://localhost:5000;
		proxy_http_version 1.1;
		proxy_set_header Connection 'upgrade';
		proxy_set_header Host $host;
		proxy_cache_bypass $http_upgrade;
	location /iapi {
		proxy_pass http://localhost:7000;
	location ~ ^/.well-known/acme-challenge/*{
		allow all;
    ssl_certificate /etc/letsencrypt/live/faruse.com/fullchain.pem; # managed by Certbot
    ssl_certificate_key /etc/letsencrypt/live/faruse.com/privkey.pem; # managed by Certbot
Managed to renew my certificates by using snap @stevenzhu Thankss! Now my certificates expires in 89 days.
But a concern of mine is when I try to do a dry run, it still gives me the same error. Is there any way to fix this?
Here's what i did to handle those validation (and bypass proxy).
Create a new folder in your nginx document root, then make two sub-folders.
basically mkdir -p /var/www/cert-validation//.well-known/acme-challenge/
		root /var/www/cert-validation/;
You need to move the above mentioned location block above all proxy blocks, thus avoiding the request being send to the proxy (tbh, I don't know if this is necessary)
Then, whenever you use webroot validation, go with --webroot-path /var/www/cert-validation/
You can reuse the same validation path for multiple website configs.
I think you might created a duplicate certificate (created a new one instead of renew the old one). You might want to dig into your letsencrypt renewal configuration files.
try sudo certbot certificates
@stevenzhu Here is what im getting:
Found the following certs:
  Certificate Name: faruse.com
    Serial Number: 480f7b570872dc50311b8727628590145cb
    Key Type: RSA
    Domains: faruse.com www.faruse.com
    Expiry Date: 2021-07-05 14:24:11+00:00 (VALID: 89 days)
    Certificate Path: /etc/letsencrypt/live/faruse.com/fullchain.pem
    Private Key Path: /etc/letsencrypt/live/faruse.com/privkey.pem
There seems to be only one certificate..
The output looks good.
When you try to renew it (--dry-run), did it say it uses DNS-01 validation? Or it still use HTTP-01?
@stevenzhu It seems to still be using http-01.
here are the logs:
Simulating renewal of an existing certificate for faruse.com and www.faruse.com
Failed to renew certificate faruse.com with error: Some challenges have failed.
All simulated renewals failed. The following certificates could not be renewed:
   Domain: faruse.com
   Type:   connection
   Detail: Fetching
   https://faruse.com/.well-known/acme-challenge/5zDlnox4raJAtB6xmOB5TEgXckeJafD-b0SAsgPTunM:
   Type:   connection
   Detail: Fetching
   https://www.faruse.com/.well-known/acme-challenge/iKn37CJAitiX6wfAobeJM3b4dvwQME0IxHKXt6-iAGw:
Then, can you show the content of /etc/letsencrypt/renewal/faruse.com? (It may be a folder, if so, please share the configuration file...)
In this case, we might need to backup the config file and attempt to modify it to save the changes. (Which should be done automatically when you renewed the certificate today)...
@schoen @griffin Can you take a look at this when you are available? I haven't use certbot for a year so I'm not confident to advise @Nicholas to modify his renewal configuration file...
@stevenzhu
here is the content of the conf file
version = 1.13.0
archive_dir = /etc/letsencrypt/archive/faruse.com
cert = /etc/letsencrypt/live/faruse.com/cert.pem
privkey = /etc/letsencrypt/live/faruse.com/privkey.pem
chain = /etc/letsencrypt/live/faruse.com/chain.pem
fullchain = /etc/letsencrypt/live/faruse.com/fullchain.pem
[renewalparams]
account = 5b50d275039d6d0a10f633fb26fa77bc
authenticator = nginx
installer = nginx
Ah i see..... Thankyou very much for your support @stevenzhu ! Would be great if I am able to automatically re new the certificates
Basically, the line authenticator should be replaced with the Cloudflare-dns parameter (Installer nginx can be leave unchanged, as it will help you reload nginx when new certificate is up). The primary issue is I have no idea what is the name of cloudflare dns in this field...
Sorry!
I see, thankyou very much for specifying where is the problem! really appreciate your support @stevenzhu
Would be looking forward to @schoen or @griffin reply
@Nicholas
Welcome to the Let's Encrypt Community :slightly_smiling_face:
I will look into this after I return from lunch.
@stevenzhu
Thanks for tagging me. Yes, I can certainly help resolve this.
Thankyou very much @griffin ! Really appereciate the support I have been getting so far :slightly_smiling_face:
Taking a bit longer than I hoped, but should be back with you in about 1.5h.
