Problem renewing a cert
I’m totally new to Let’s Encrypt and certbot and trying to renew a cert after receiving a mail about a cert getting old. I have not renewed the cert before nor am I its original installer, so I don’t know any details about how it was set up.
vanilla.puheet.site
certbot renew
(I tried the dry-run flag as well and it was able to successfully “renew” other certs that are not yet due for renewal. )
Processing /etc/letsencrypt/renewal/vanilla.puheet.site.conf
Attempting to renew cert (vanilla.puheet.site) from /etc/letsencrypt/renewal/vanilla.puheet.site.conf produced an unexpected error: HTTPSConnectionPool(host='acme-v02.api.letsencrypt.org', port=443): Read timed out. (read timeout=45). Skipping.
  /etc/letsencrypt/live/pointrsurvey.inputchannel.com/fullchain.pem (failure)
  /etc/letsencrypt/live/vanilla.puheet.site/fullchain.pem (failure)
nginx version: nginx/1.14.0 (Ubuntu)
Ubuntu 18.04.1 LTS
Yes.
No.
certbot --version output: certbot 0.28.0
Hi @platyrat
please answer the following questions:
@JuergenAuer I updated my post accordingly.
That looks like an error with an outgoing connection. Is your server able to connect Letsencrypt?
Try something like
ping acme-v02.api.letsencrypt.org
curl acme-v02.api.letsencrypt.org
And share
/var/log/letsencrypt/letsencrypt.log
to see, if the error happens when your Cerbot creates a new order or later.
ping acme-v02.api.letsencrypt.org:
PING e14990.dscx.akamaiedge.net (95.100.12.214) 56(84) bytes of data.
64 bytes from a95-100-12-214.deploy.static.akamaitechnologies.com (95.100.12.214): icmp_seq=1 ttl=58 time=6.03 ms
64 bytes from a95-100-12-214.deploy.static.akamaitechnologies.com (95.100.12.214): icmp_seq=2 ttl=58 time=5.62 ms
64 bytes from a95-100-12-214.deploy.static.akamaitechnologies.com (95.100.12.214): icmp_seq=3 ttl=58 time=5.62 ms
64 bytes from a95-100-12-214.deploy.static.akamaitechnologies.com (95.100.12.214): icmp_seq=4 ttl=58 time=5.62 ms
64 bytes from a95-100-12-214.deploy.static.akamaitechnologies.com (95.100.12.214): icmp_seq=5 ttl=58 time=5.63 ms
^C
--- e14990.dscx.akamaiedge.net ping statistics ---
5 packets transmitted, 5 received, 0% packet loss, time 4007ms
rtt min/avg/max/mdev = 5.623/5.710/6.038/0.164 ms
curl -i acme-v02.api.letsencrypt.org:
Server: AkamaiGHost
Content-Length: 0
Expires: Thu, 02 May 2019 10:23:44 GMT
Cache-Control: max-age=0, no-cache, no-store
Pragma: no-cache
Date: Thu, 02 May 2019 10:23:44 GMT
After trying ping and curl I ran certbot renew again to catch only the most recent output from the renewal attempt, and this time the renewal succeeded. I have no idea why. I didn’t change anything and had ran the command probably a dozen times by this point. Maybe ping and curl contain some magic. :stuck_out_tongue:
Anyway, thanks for the help!
Curious.
Perhaps there were wrong cached dns entries.
But happy to read that it works now.
