Unable to renew SSL certificate using certbot
I'm trying to renew my SSL certificate in my AWS EC2 server but I'm getting the following error so after a lot of research I couldn't find the solution.
$ sudo certbot renew --dry-run
Processing /etc/letsencrypt/renewal/mydomain.com.conf
http-01 challenge for mydomain.com
Using default addresses 80 and [::]:80 ipv6only=on for authentication.
Challenge failed for domain mydomain.com
Attempting to renew cert (mydomain.com) from /etc/letsencrypt/renewal/prod-mydomain.conf produced an unexpected error: Some challenges have failed.. Skipping.
  /etc/letsencrypt/live/mydomain.com/fullchain.pem (failure)
   Domain: mydmain.com
   Type:   unauthorized
   Detail: 2.211.168.8: Invalid response from
   http://mydoamin.com/.well-known/acme-challenge/ov6EBHInETwkZZ-oqLNI908jFXvN7PFK86ZCJYcdrtA:
   404
My domain is: prod-backend.alectify.com
The operating system my web server runs on is: Ubuntu 20.4
My hosting provider, if applicable, is: godady and using route 53
I'm using the terminal to login into my server
The version of my client is: 0.40.0
Hi @zainkhan, and welcome to the LE community forum :slight_smile:
You have not provided enough information for anyone to help you with.
Hi @rg305, I've updated my question
We need to have a look at the renewal conf and the certificates:
cat /etc/letsencrypt/renewal/prod-*
certbot certificates
version = 0.40.0
archive_dir = /etc/letsencrypt/archive/prod-backend.alectify.com
cert = /etc/letsencrypt/live/prod-backend.alectify.com/cert.pem
privkey = /etc/letsencrypt/live/prod-backend.alectify.com/privkey.pem
chain = /etc/letsencrypt/live/prod-backend.alectify.com/chain.pem
fullchain = /etc/letsencrypt/live/prod-backend.alectify.com/fullchain.pem
[renewalparams]
account = ef20bbb8bca7d645438e5368b9048dee
authenticator = nginx
installer = nginx
Show:
Found the following certs:
  Certificate Name: prod-backend.alectify.com
    Domains: prod-backend.alectify.com
    Expiry Date: 2022-07-03 23:52:05+00:00 (INVALID: EXPIRED)
    Certificate Path: /etc/letsencrypt/live/prod-backend.alectify.com/fullchain.pem
    Private Key Path: /etc/letsencrypt/live/prod-backend.alectify.com/privkey.pem
Let's have a look at:
nginx -T
user www-data;
worker_processes auto;
pid /run/nginx.pid;
events {
	worker_connections 768;
	# multi_accept on;
http {
	# Basic Settings
	sendfile on;
	tcp_nopush on;
	tcp_nodelay on;
	keepalive_timeout 200;
	types_hash_max_size 2048;
	# server_tokens off;
	# SSL Settings
	ssl_protocols TLSv1 TLSv1.1 TLSv1.2 TLSv1.3; # Dropping SSLv3, ref: POODLE
	ssl_prefer_server_ciphers on;
	# Logging Settings
	# Gzip Settings
	gzip on;
	# gzip_vary on;
	# gzip_proxied any;
	# gzip_comp_level 6;
	# gzip_buffers 16 8k;
	# gzip_http_version 1.1;
	# Virtual Host Configs
#mail {
#	# See sample authentication script at:
#	# http://wiki.nginx.org/ImapAuthenticateWithApachePhpScript
#	# auth_http localhost/auth.php;
#	# pop3_capabilities "TOP" "USER";
#	# imap_capabilities "IMAP4rev1" "UIDPLUS";
#	server {
#		listen     localhost:110;
#		protocol   pop3;
#		proxy      on;
#	server {
#		listen     localhost:143;
#		protocol   imap;
#		proxy      on;
types {
    text/html                             html htm shtml;
    text/css                              css;
    text/xml                              xml;
    image/gif                             gif;
    image/jpeg                            jpeg jpg;
    application/javascript                js;
    application/atom+xml                  atom;
    application/rss+xml                   rss;
    text/mathml                           mml;
    text/plain                            txt;
    text/vnd.sun.j2me.app-descriptor      jad;
    text/vnd.wap.wml                      wml;
    text/x-component                      htc;
    image/png                             png;
    image/tiff                            tif tiff;
    image/vnd.wap.wbmp                    wbmp;
    image/x-icon                          ico;
    image/x-jng                           jng;
    image/x-ms-bmp                        bmp;
    image/svg+xml                         svg svgz;
    image/webp                            webp;
    application/font-woff                 woff;
    application/java-archive              jar war ear;
    application/json                      json;
    application/mac-binhex40              hqx;
    application/msword                    doc;
    application/pdf                       pdf;
    application/postscript                ps eps ai;
    application/rtf                       rtf;
    application/vnd.apple.mpegurl         m3u8;
    application/vnd.ms-excel              xls;
    application/vnd.ms-fontobject         eot;
    application/vnd.ms-powerpoint         ppt;
    application/vnd.wap.wmlc              wmlc;
    application/vnd.google-earth.kml+xml  kml;
    application/vnd.google-earth.kmz      kmz;
    application/x-7z-compressed           7z;
    application/x-cocoa                   cco;
    application/x-java-archive-diff       jardiff;
    application/x-java-jnlp-file          jnlp;
    application/x-makeself                run;
    application/x-perl                    pl pm;
    application/x-pilot                   prc pdb;
    application/x-rar-compressed          rar;
    application/x-redhat-package-manager  rpm;
    application/x-sea                     sea;
    application/x-shockwave-flash         swf;
    application/x-stuffit                 sit;
    application/x-tcl                     tcl tk;
    application/x-x509-ca-cert            der pem crt;
    application/x-xpinstall               xpi;
    application/xhtml+xml                 xhtml;
    application/xspf+xml                  xspf;
    application/zip                       zip;
    application/octet-stream              bin exe dll;
    application/octet-stream              deb;
    application/octet-stream              dmg;
    application/octet-stream              iso img;
    application/octet-stream              msi msp msm;
    application/vnd.openxmlformats-officedocument.wordprocessingml.document    docx;
    application/vnd.openxmlformats-officedocument.spreadsheetml.sheet          xlsx;
    application/vnd.openxmlformats-officedocument.presentationml.presentation  pptx;
    audio/midi                            mid midi kar;
    audio/mpeg                            mp3;
    audio/ogg                             ogg;
    audio/x-m4a                           m4a;
    audio/x-realaudio                     ra;
    video/3gpp                            3gpp 3gp;
    video/mp2t                            ts;
    video/mp4                             mp4;
    video/mpeg                            mpeg mpg;
    video/quicktime                       mov;
    video/webm                            webm;
    video/x-flv                           flv;
    video/x-m4v                           m4v;
    video/x-mng                           mng;
    video/x-ms-asf                        asx asf;
    video/x-ms-wmv                        wmv;
    video/x-msvideo                       avi;
# configuration file /etc/nginx/sites-enabled/default:
# https://www.nginx.com/resources/wiki/start/
# https://www.nginx.com/resources/wiki/start/topics/tutorials/config_pitfalls/
# https://wiki.debian.org/Nginx/DirectoryStructure
# In most cases, administrators will remove this file from sites-enabled/ and
# leave it as reference inside of sites-available where it will continue to be
# updated by the nginx packaging team.
# This file will automatically load configuration files provided by other
# applications, such as Drupal or Wordpress. These applications will be made
# available underneath a path with that package name, such as /drupal8.
	# SSL configuration
	root /var/www/html;
	server_name prod-backend.alectify.com;
	client_max_body_size 64M;
#	location / {
#		# First attempt to serve request as file, then
#		# as directory, then fall back to displaying a 404.
#		try_files $uri $uri/ =404;
		proxy_pass http://localhost:80;
		proxy_set_header Host $host;
	#location ~ \.php$ {
	#	include snippets/fastcgi-php.conf;
	#	# With php-fpm (or other unix sockets):
	#	fastcgi_pass unix:/var/run/php/php7.4-fpm.sock;
	#	# With php-cgi (or other tcp sockets):
	#	fastcgi_pass 127.0.0.1:9000;
	# concurs with nginx's one
	#location ~ /\.ht {
	#	deny all;
    ssl_certificate /etc/letsencrypt/live/prod-backend.alectify.com/fullchain.pem; # managed by Certbot
    ssl_certificate_key /etc/letsencrypt/live/prod-backend.alectify.com/privkey.pem; # managed by Certbot
#server {
#	listen 80;
#	listen [::]:80;
#	server_name example.com;
#	root /var/www/example.com;
#	index index.html;
#	location / {
    if ($host = prod-backend.alectify.com) {
    } # managed by Certbot
	listen 8080 default_server;
	listen [::]:8080 default_server;
# configuration file /etc/letsencrypt/options-ssl-nginx.conf:
# this file.
ssl_session_cache shared:le_nginx_SSL:10m;
ssl_session_timeout 1440m;
ssl_session_tickets off;
ssl_prefer_server_ciphers off;
ssl_ciphers "ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:ECDHE-RSA-AES128-SHA";
There is no port 80 HTTP server block.
HTTP authentication requires one.
ooh man, thank you so much for the guidance. The issue has been fixed now after adding port 80.
after the renewal of SSL, my site is still showing not secure. Do you know the reason?
The cert being served expired more than one day ago.
Please show:
Then the cert hasn't been renewed yet.
Try this again (and show the result):
Also, I do see some certs being issued today by Amazon:
crt.sh | prod-backend.alectify.com
Processing /etc/letsencrypt/renewal/prod-backend.alectify.com.conf
http-01 challenge for prod-backend.alectify.com
new certificate deployed with reload of nginx server; fullchain is
/etc/letsencrypt/live/prod-backend.alectify.com/fullchain.pem (success)
OK, then get an actual cert with:
sudo certbot renew
it's done, thank you so much. God bless you :heart:
