Renewal problems after upgrading certbot
I started with letsencrypt before there was an ubuntu package of certbot (i.e. previously using letsencrypt_auto). I've recently upgraded to use certbot (version 0.23.0 on ubuntu 18.04), but now renew is failing. I'm using the Apache plugin.
$ certbot renew --dry-run
Attempting to renew cert (MYDOMAIN.org) from /etc/letsencrypt/renewal/MYDOMAIN.org.conf produced an unexpected error: Failed authorization procedure. MYDOMAIN.org (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from https://MYDOMAIN.org/.well-known/acme-challenge/j-o_KAnVLIk5_WKVksXsFrIJ5tfErPudurIplF2rwvk [206.189.123.47]: "\n\n404 Not Found\n\n
Not Found
\n<p". Skipping.
From poking around it looks as though the Apache config is being updated to serve .well-known/acme-challenge/... from /var/lib/letsencrypt/http_challenges, which is fine except it seems my redirect to https is happening first, so the result is a 404.
<VirtualHost *:80>
    ServerName www.MYDOMAIN.org
    CustomLog /var/log/apache2/access.MYDOMAIN.log combined
    RewriteEngine on
    RewriteCond %{SERVER_NAME} =www.MYDOMAIN.org
</VirtualHost>
This worked previously, and the failure seems basic so I'm not sure what's wrong. Anyone help me work out what's up?
Hi @joewalker
please answer the following questions (template in Help ):
My domain is: alsdiary.org
I ran this command: certbot renew --dry-run
It produced this output: Attempting to renew cert (alsdiary.org) from /etc/letsencrypt/renewal/alsdiary.org.conf produced an unexpected error: Failed authorization procedure. alsdiary.org (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from https://alsdiary.org/.well-known/acme-challenge/j-o_KAnVLIk5_WKVksXsFrIJ5tfErPudurIplF2rwvk [206.189.123.47]: "<!DOCTYPE HTML PUBLIC \"-//IETF//DTD HTML 2.0//EN\">\n<html><head>\n<title>404 Not Found</title>\n</head><body>\n<h1>Not Found</h1>\n<p". Skipping.
My web server is (include version): Apache 2.4.29
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): 0.23.0
Should be updated to 0.28.0 (if possible).
TLS-SNI-01 (HTTPS) authentication will soon be completely shutoff.
That said, it should have renewed today...
Please show file:
And the vhost config for port 443 covering site alsdiary.org
Actually this is a bit confusing:
The "brown out" period of (I think) 1 week has started recently. See March 13, 2019: End-of-Life for All TLS-SNI-01 Validation Support - #4 by jsha
Checking your domain there is one curious thing ( https://check-your-website.server-daten.de/?q=alsdiary.org ):
Your http + non-www redirects to https, that's ok. But your www-version doesn't redirect.
Your certbot is old, perhaps certbot doesn't understand your configuration -> update or use certbot-auto.
The vHosts of http + www and https + non-www: Do they have the same DocumentRoot?
If yes, use something like
certbot certonly -a webroot -w yourDocumentRoot -d alsdiary.org -d www.alsdiary.org --dry-run
PS: That may be part of the problem.
Add your non-www as Alias:
ServerName www.alsdiary.org
ServerAlias alsdiary.org
Then both have the same vHost - only one vHost port 80.
This sounds like it’s the root of the problem. I’ll check this out (and upgrade certbot too).
Thanks for the help - I’ll report back
So the apache update is still broken, but I think I have a workaround.
certbot --version is now 0.28.0. The redirects are fixed (I broken them while trying to diagnose what was up). https://check-your-website.server-daten.de/?q=alsdiary.org is now green.
However (formatted for clarity):
                Invalid response from https://alsdiary.org/.well-known/acme-challenge/0rxu5DvuGvYP059tzj2-T9-JYtvM3lvOv9tFvejMv0k [206.189.123.47]:
Skipping.
The following certs could not be renewed:
  /etc/letsencrypt/live/alsdiary.org/fullchain.pem (failure)
It still looks as though the Apache config is being updated to serve .well-known/acme-challenge/… from /var/lib/letsencrypt/http_challenges, which is fine except it seems my redirect to https is happening first, so the result is a 404 (because the https site doesn’t have the same config update)
Now it seems that certbot certonly -a webroot -w /web/root -d alsdiary.org -d www.alsdiary.org --dry-run works OK, so perhaps I have a workaround.
Yes, it's green, Grade A is very good. But there you see the problem:
You have two connections - this if normal, one ip address, one non-www, one www.
But two certificates are listed:
CN=alsdiary.org
	05.01.2019
	05.04.2019
expires in 48 days	alsdiary.org - 1 entry
CN=alsdiary.org
	16.02.2019
	17.05.2019
expires in 90 days	alsdiary.org, www.alsdiary.org - 2 entries
So you must have two different VirtualHosts with different certificates.
So add alsdiary.org as ServerAlias to your www.alsdiary.org - vHost and remove the standalone alsdiary.org vHost.
Thanks for your help:
I fixed that problem - There is only one certificate now:
$ certbot certificates
Found the following certs:
  Certificate Name: alsdiary.org
    Domains: alsdiary.org www.alsdiary.org
    Expiry Date: 2019-05-17 14:38:09+00:00 (VALID: 89 days)
    Certificate Path: /etc/letsencrypt/live/alsdiary.org/fullchain.pem
    Private Key Path: /etc/letsencrypt/live/alsdiary.org/privkey.pem
However this doesn’t fix the problem: The error message from certbot renew --dry-run is unchanged.
Yep, now your two connections use the same certificate with two domain names:
CN=alsdiary.org
	16.02.2019
	17.05.2019
You have a brand-new certificate, so you can ignore the error.
And in two months, instead of
use
certbot run -a webroot -w /web/root -d alsdiary.org -d www.alsdiary.org -i apache
one time, then your config file should be new. Perhaps now your config file has the old values. More then one vHost with the same name is sometimes a problem.
OK - I think this will work - Thanks for your help. I’ve been tearing my hair out about this, and you’ve been super helpful.
