Had to renew and it was hard looks like it worked
I was getting close to have to renew and I did the same as last time but this time it said do a apt install certbot last time I had to install it with a git@github.com:certbot/certbot.git
Then doing a certbot renew got RED color errors. Replace my real domain name with XXXX.XXX
Attempting to renew cert (XXXX.XXX-0001) from /etc/letsencrypt/renewal/XXXX.XX-0001.conf produced an unexpected error: Failed authorization procedure. XXXX.XX (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://XXXX.XXX/.well-known/acme-challenge/x057a6BUHC_zmq68468LXO1BRcJV6QdIMZap_MN38f0: Timeout during connect (likely firewall problem). Skipping.
Maybe it was because it shows a http and not a https in the fetching red part.
Looks like it worked when I did this:
root@rayday:/media/6TB/USBdisk2-3TB/root/letsencrypt# certbot run -a webroot -i apache -w /media/6TB/USBdisk2-3TB/var/www -d XXXX.XXX
Plugins selected: Authenticator webroot, Installer apache
Cert not yet due for renewal
(ref: /etc/letsencrypt/renewal/XXXX.XXX.conf)
What would you like to do?
http-01 challenge for XXXX.XXX
Using the webroot path /media/6TB/USBdisk2-3TB/var/www for all unmatched domains.
Failed authorization procedure. XXXX.XXX (http-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://XXXX.XXX/.well-known/acme-challenge/Iii8GxdSguDOVmcWwVlxzHjTjFJNC_bURhrzqtAVsYI: Timeout during connect (likely firewall problem)
   Domain: XXXX.XXX
   Type:   connection
   Detail: Fetching
root@rayday:/media/6TB/USBdisk2-3TB/root/letsencrypt# ssl-cert-check -c /etc/letsencrypt/live/XXXX.XXX/cert.pem
Host                                            Status       Expires      Days
FILE:/etc/letsencrypt/live/XXXX.XXX/cert.pem   Valid        Sep 9 2018   90
It says 90 days now so looks like it worked. Maybe this will help some one else.
-Raymond Day
Please share us some information so we could help you...
Thank you
Hi @Ray
the http-01 - challenge uses always http / Port 80. So this port must be available. If a firewall blocks this port or if there is no http-service there, http-01 - challenge will fail.
That must be it I said to only use https and not both when I set it up.
It’s a open port to my home internet running on a Intel compute stick with Ubuntu server on it. So yes can login as root. No control panel. If any thing have Webmin on it but don’t have a open port on 10000 it’s port so just get to it on my LAN.
