Can't renew a cert with certbot: Timeout during connect (likely firewall problem)
My domain is: app.senyxwh.com
I ran this command: certbot-auto renew --standalone
$ certbot-auto renew --standalone
Processing /etc/letsencrypt/renewal/app.senyxwh.com.conf
http-01 challenge for app.senyxwh.com
Waiting for verification…
Challenge failed for domain app.senyxwh.com
Attempting to renew cert (app.senyxwh.com) from /etc/letsencrypt/renewal/app.senyxwh.com.conf produced an unexpected error: Some challenges have failed… Skipping.
/etc/letsencrypt/live/app.senyxwh.com/fullchain.pem (failure)
    Domain: app.senyxwh.com
    Type: connection
    Detail: Fetching
    http://app.senyxwh.com/.well-known/acme-challenge/9NRlgCyMzP5fHXTO9KaXYZrC1aNtQJzTsn6W2Cr0GYs:
My web server is (include version): Apache 2.4
The operating system my web server runs on is (include version): Ubuntu 16.04.6 LTS (GNU/Linux 4.4.0-1112-aws x86_64)
My hosting provider, if applicable, is: AWS Lightsail
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): Certbot 1.7.0
In order to renew the certificate, I need to stop the apache 2. Otherwise, I get this error.
Attempting to renew cert (app.senyxwh.com) from /etc/letsencrypt/renewal/app.senyxwh.com.conf produced an unexpected error: Problem binding to port 80: Could not bind to IPv4 or IPv6… Skipping.
I’ve checked post that has a similar situation as me on the forum, but I couldn`t figure out the solution. Could anyone help me to fix this?
Hi @dhdhxk
that's only correct if you use --standalone.
Use --apache or --webroot to use your running webserver.
Check
https://certbot.eff.org/docs/using.html
Hi, @JuergenAuer. Thank you for your answer.
I`m using Lightsail and it use bitnami Apache2. I tried this.
$ certbot-auto --apache
The apache plugin is not working; there may be problems with your existing configuration.
The error was: NoInstallationError(‘Cannot find Apache executable apache2ctl’,)
and it does not find the apache2.
Please. If you use Bitnami, there are own rules and own scripts to create a certificate.
Check the Bitnami documentation to find a solution. Then it's expected that the standard Certbot will not work.
Thank you! JuergenAuer.
I’ve realized I use the Certbot wrong way. I`ll research it! Thank you.
