Failed to renew: Timeout during connect (likely firewall rules)
My domain is: biosymphony.hmbdbio.bio
I ran this command: sudo certbot renew -v
Certificate is due for renewal, auto-renewing...
Simulating renewal of an existing certificate for biosymphony.hmbdbio.bio
http-01 challenge for biosymphony.hmbdbio.bio
Challenge failed for domain biosymphony.hmbdbio.bio
Domain: biosymphony.hmbdbio.bio
Type: connection
Detail: Fetching http://biosymphony.hmbdbio.bio/.well-known/acme-challenge/qwEQ9I2G1WrlPuqQ0cYNw-rAFzoDQLxI1VPGVzGMqgA: Timeout during connect (likely firewall problem)
Failed to renew certificate biosymphony.hmbdbio.bio with error: Some challenges have failed.
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 1.22.0
Welcome to the community @NorhishamMN
Have you added a firewall recently? Because I cannot reach your website from the US or several other places around the globe.
The Let's Debug test site (link here) shows the error you see above
Or, maybe your IP address changed? The DNS says 20.195.49.110
Hi @MikeMcQ ,
Thank you for the reply, sorry for the delayed reply
IP Address is same nothing is changed, its a public ipv4 address that was created in Azure
Port 80 is already open from source to public IP
Hi @MikeMcQ ,
Sorry found out what the issue was, I was typing earlier that Port 80 is open from source to public
Then it strikes me, port 80 should open for everything for cert to renew
Did that and it works :smile:
Thank you!
