Cert renew timeout at validation (likely firewall problem)
My domain is: maillebymicah.com
I ran this command: sudo certbot renew
Processing /etc/letsencrypt/renewal/maillebymicah.com.conf
Renewing an existing certificate for maillebymicah.com and www.maillebymicah.com
Domain: maillebymicah.com
Type: connection
Detail: 98.60.54.35: Fetching http://maillebymicah.com/.well-known/acme-challenge/-ECm1jfade_H_xXRlZ2qGfQC4ikqpQBbOAUSCs1erlk: Timeout during connect (likely firewall problem)
Domain: www.maillebymicah.com
Type: connection
Detail: 98.60.54.35: Fetching http://www.maillebymicah.com/.well-known/acme-challenge/XNov328oLMddq4R2o-AEGYStT3LSjQJe1stlUtFbtfY: Timeout during connect (likely firewall problem)
Failed to renew certificate maillebymicah.com with error: Some challenges have failed.
/etc/letsencrypt/live/maillebymicah.com/fullchain.pem (failure)
I ran this command: sudo certbot -auto --apache
We recommend selecting either all domains, or all domains in a VirtualHost/server block.
1: maillebymicah.com
2: www.maillebymicah.com
Attempting to parse the version 3.0.1 renewal configuration file found at /etc/letsencrypt/renewal/maillebymicah.com.conf with version 2.9.0 of Certbot. This might not work.
Certificate is due for renewal, auto-renewing...
http-01 challenge for maillebymicah.com
http-01 challenge for www.maillebymicah.com
Challenge failed for domain maillebymicah.com
Challenge failed for domain www.maillebymicah.com
Type: connection
Detail: 98.60.54.35: Fetching http://maillebymicah.com/.well-known/acme-challenge/xMcLL5-s8f8V-HTeijIzS5pCRQYMxUKyLMScrtF48mU: Timeout during connect (likely firewall problem)
Type: connection
Detail: 98.60.54.35: Fetching http://www.maillebymicah.com/.well-known/acme-challenge/aqBTRIz86xUkdWZ6Qfz0Lw4z7NPJTvLXz5TbDudTi2I: Timeout during connect (likely firewall problem)
My web server is (include version): apache2 2.4.58
The operating system my web server runs on is (include version): Ubuntu 24.04.2
My hosting provider, if applicable, is:N/A
I'm using a control panel to manage my site (no, or provide the name and version of the control panel):direct access and through Webmin 2.303
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot):certbot 2.9.0
Am running UFW and have attempted renewing my cert with firewall enabled and disabled.
I have tried reconfiguring and disabling IPv6 (have reset to autocinfig settings).
apachectl -t -D DUMP_VHOSTS
VirtualHost configuration:
*:443 maillebymicah.com (/etc/apache2/sites-enabled/maillebymicah-le-ssl.conf:2)
*:80 maillebymicah.com (/etc/apache2/sites-enabled/maillebymicah.conf:1)
sudo ufw status
Status: active
To Action From
Apache Full ALLOW Anywhere
OpenSSH ALLOW Anywhere
8080 ALLOW Anywhere
10000 ALLOW Anywhere
22 ALLOW Anywhere
17540 ALLOW Anywhere
443 ALLOW Anywhere
Apache Full (v6) ALLOW Anywhere (v6)
OpenSSH (v6) ALLOW Anywhere (v6)
8080 (v6) ALLOW Anywhere (v6)
10000 (v6) ALLOW Anywhere (v6)
22 (v6) ALLOW Anywhere (v6)
17540 (v6) ALLOW Anywhere (v6)
443 (v6) ALLOW Anywhere (v6)
I am using a wired connection to an Xfinity router, for my sins. Port forwarding has been set up and the server has a dedicated IP address.
Hello @MicahMaiiTso,
The HTTP-01 challenge states "The HTTP-01 challenge can only be done on port 80."
Best Practice - Keep Port 80 Open
I see Port 80 being filtered (i.e. not accessible from the Public Facing Internet).
$ nmap -Pn -p80,443 maillebymicah.com
Starting Nmap 7.94SVN ( https://nmap.org ) at 2025-04-11 23:45 UTC
Nmap scan report for maillebymicah.com (98.60.54.35)
Host is up (0.065s latency).
rDNS record for 98.60.54.35: c-98-60-54-35.hsd1.nm.comcast.net
PORT    STATE    SERVICE
80/tcp  filtered http
443/tcp open     https
Nmap done: 1 IP address (1 host up) scanned in 1.86 seconds
Hi @MicahMaiiTso,
Additionally the online tool Let's Debug yields these results (basically the same information). https://letsdebug.net/maillebymicah.com/2417862
And the online too https://www.yougetsignal.com/tools/open-ports/ shows
And from around the world Permanent link to this check report using https://check-host.net/
shows "Connection timed out".
Please check all your firewalls and routers (maybe even called modems) between your server and the Public Facing Internet.
One way to check is to use a cellphone with Wi-Fi disable so that you are going through the cell carrier's network instead of the LAN.
thank you for catching this. I had switched out my server hardware to something a little newer/faster, and the router was being awkward with the static IP address. I got that sorted out and it threw the port forwarding out...
