Problem with certificate - renew using certbot renew
Hi!
Please i need your help. i have a problem with renewing my existing certificate with certbot.
certbot renew
Processing /etc/letsencrypt/renewal/correo.laboratorioturner.com.ar.conf
http-01 challenge for correo.laboratorioturner.com.ar
Waiting for verification…
Attempting to renew cert (correo.laboratorioturner.com.ar) from /etc/letsencrypt/renewal/correo.laboratorioturner.com.ar.conf produced an unexpected error: Failed authorization procedure. correo.laboratorioturner.com.ar (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://correo.laboratoriotuturner.com.ar/.well-know/acme-challenge/qkXaDFwswKXDzK_Zy-L00Opm2cio5sETjqxSyU9JAC4: Timeout during connect (likely firewall problem). Skipping
/etc/letsencrypt/live/correo.laboratorioturner.com.ar/fullchain.pem (failure)
Domain:correo.laboratorioturner.com.ar
Type: connection
Detail: Featchig
The operating system my server runs on is CentOS
I can login to a root shell on my machinei sent “certbot -renew” from my root shell
The version of my client is: certbot 0.29.1
Hi @dlacomba
see your check, ~~one hour old - https://check-your-website.server-daten.de/?q=correo.laboratorioturner.com.ar
• http://correo.laboratorioturner.com.ar/ 186.153.151.4 -14 10.017 T
Timeout - The operation has timed out
• https://correo.laboratorioturner.com.ar/ 186.153.151.4 GZip used - 4816 / 13038 - 63,06 % Inline-JavaScript (∑/total): 2/6794 Inline-CSS (∑/total): 0/0 200 Html is minified: 342,92 % 6.680 B
• http://correo.laboratorioturner.com.ar/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 186.153.151.4 -14 10.023 T
https answers, http not.
So http validation can't work. A working port 80 is required.
The “likely firewall problem” is usually correct in this case—port 80 may be “working” on the web server (from Certbot’s point of view, at least) but inbound connections to it are still blocked by a firewall. If there were no firewall, we would expect to see “connection refused” rather than “timeout”.
