Timeout when renewing certificate
My domain is: https://lakehillshortmat.now-dns.org/
I ran this command: /usr/bin/certbot renew --preferred-challenges http --pre-hook “service apache2 stop” --post-hook “service apache2 start”
Processing /etc/letsencrypt/renewal/lakehillshortmat.now-dns.org.conf
Running pre-hook command: service apache2 stop
http-01 challenge for lakehillshortmat.now-dns.org
http-01 challenge for lasalle.now-dns.org
Waiting for verification…
Attempting to renew cert from /etc/letsencrypt/renewal/lakehillshortmat.now-dns.org.conf
produced an unexpected error: Failed authorization procedure. lasalle.now-dns.org (http
-01): urn:acme:error:connection :: The server could not connect to the client to verify
the domain :: Fetching http://lasalle.now-dns.org/.well-known/acme-challenge/54NQ_6QaZ9K
t1lejFm6X-ocCQ8cet-Whs8c23wCddR4: Timeout during connect (likely firewall problem). Skip
ping.
/etc/letsencrypt/live/lakehillshortmat.now-dns.org/fullchain.pem (failure)
Running post-hook command: service apache2 start
Domain: lasalle.now-dns.org
Type: connection
Detail: Fetching
http://lasalle.now-dns.org/.well-known/acme-challenge/54NQ_6QaZ9Kt1lejFm6X-ocCQ8cet-W
hs8c23wCddR4:
My web server is (include version): Apache 2.4
The operating system my web server runs on is (include version): debian linux version 9
My hosting provider, if applicable, is: shaw.ca
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.10.2
I am 99.99% coinfident that incoming port 80 is not blocked by my ISP: I got my neighbour to connect via http, and I tried the same thing using a virtual machine whose network connection is via a VPN, I also managed to telnet to port 80.
This certificate renew with no problem several times already this year and I am 99.99% certain that I have changed nothing that would affect it (only changes I made were to the web app running on the server).
thanks in advance for your help.
OK, solved my own problem. There were two different domain names associated with the same IP address.
or, rather, it should have been the same IP, but one of the domain names had not been updated and was resolving to an out-of-date IP.
Having updated the IP at now-dns.org, everything is now OK.
