Timeout during connect (likely firewall problem) unable to renew certificate
My domain is:ppupload1.co.uk
I ran this command:sudo certbot -v renew --dry-run
It produced this output:Processing /etc/letsencrypt/renewal/ppupload1.co.uk.conf
Certificate is due for renewal, auto-renewing...
Simulating renewal of an existing certificate for ppupload1.co.uk and www.ppupload1.co.uk
http-01 challenge for ppupload1.co.uk
http-01 challenge for www.ppupload1.co.uk
Challenge failed for domain ppupload1.co.uk
Challenge failed for domain www.ppupload1.co.uk
Domain: ppupload1.co.uk
Type: connection
Detail: 109.228.47.235: Fetching http://ppupload1.co.uk/.well-known/acme-challenge/lO0TlQfyG_W04nCeCTZsqPNtm2MiRhS9b_J4zKIA_4A: Timeout during connect (likely firewall problem)
Domain: www.ppupload1.co.uk
Type: connection
Detail: 109.228.47.235: Fetching http://www.ppupload1.co.uk/.well-known/acme-challenge/PZzrFIm78H9S5PBh-PcMvIrFGMlRL33NBu6jiwmoZpE: Timeout during connect (likely firewall problem)
My web server is (include version):Apache/2.4.52 (Ubuntu)
The operating system my web server runs on is (include version):Ubuntu 22.04.5 LTS
My hosting provider, if applicable, is:fasthosts
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot):certbot 1.21.0
I have made sure port 80 is open. I have even disabled the firewall completely and then reenabled just to check.
The renewal has worked flawlessly over the last year and then I went to renew on 2nd of Nov as it was due to expire on the 3rd and I got the errors in the post.
My ssl has now expired. Any help would be very greatly appreciated.
Have you checked from outside your network? Here's one tool I sometimes use; it shows that nobody can connect:
Thank you for the prompt reply. Just used that tool and all looks ok.
An HTTP test is failing now. Did you change something ? Or, did you run one of the other tests instead of HTTP?
Here's the permalink to the HTTP test I just ran: Check website performance and response : Check host - online website monitoring
