Too Many Redirects
My domain is: hirnschall.bio
My web server is (include version): nginx/1.18.0
The operating system my web server runs on is (include version): Debian 11
My hosting provider, if applicable, is: vultr
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.32.2
I keep getting a too_many_redirects error after installing my certificate with Cerbot.
I followed this guide and did nothing else on the server How to Install Nginx, MariaDB & PHP (LEMP) on Debian 11 - Vultr.com
Thanks in advance for your help
Jakob
You need to review your Cloudflare redirect settings and how those interact with your Origin Server. The Cloudflare community (here) is best place to ask about this.
What is happening is that an HTTP request gets redirected to HTTPS (which is good). But, that HTTPS request is redirected back to HTTP and the sequence repeats forever.
curl -iL hirnschall.bio
Server: cloudflare
HTTP/2 301
server: cloudflare
Server: cloudflare
HTTP/2 301
server: cloudflare
While the Cloudflare Community is definitely the right place for this topic, I can quickly share that the most common cause of ERR TOO MANY REDIRECTS is having your Cloudflare SSL set to Flexible instead of Full (Strict). Flexible sends requests from Cloudflare to the origin over insecure HTTP. This makes it easy to get stuck in an infinite loop by an HTTP -> HTTPS redirect on the origin server.
Thanks linkp
I changed the SSL mode of Cloudflare and now everything works.
Thanks a lot
With kind regards,
Jakob
