Err_too_many_redirects
My domain is: maillist.naturalintelligence.us
I ran this command: via broswer https://maillist.naturalintelligence.us/
It produced this output: ERR_TOO_MANY_REDIRECTS
My web server is (include version): nginx/1.18.0 (Ubuntu)
The operating system my web server runs on is (include version): Ubuntu 20.04.1 LTS
My hosting provider, if applicable, is: self
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 1.7.0
nginx error.log output
2020/09/07 05:06:34 [error] 4105#4105: *26368 open() “/var/www/html/GponForm/diag_Form” failed (2: No such file or directory), client: 64.227.110.183, server: _, request: “POST /GponForm/diag_Form?style/ HTTP/1.1”, host: “192.168.0.1:443”
nginx access.log output
157.131.253.99 - - [07/Sep/2020:06:00:19 -0700] “GET / HTTP/1.1” 301 162 “-” “Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/85.0.4183.83 Safari/537.36”
Hi @walpi
checking your domain - https://check-your-website.server-daten.de/?q=maillist.naturalintelligence.us#url-checks
It's a wrong https + non-www -> https + non-www redirect.
Find and remove that redirect.
Thank you; however, I don’t see the offending line in my server block (see below). I’m not using the ‘www’ in my hostname or DNS at all. Please advise further.
# Listen on ipv4
server_name maillist.naturalintelligence.us;
# Redirect all insecure http:// requests to https://
ssl_certificate /etc/letsencrypt/live/maillist.naturalintelligence.us/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/maillist.naturalintelligence.us/privkey.pem; # managed by Certbot
if ($host = maillist.naturalintelligence.us) {
} # managed by Certbot
listen 80;
listen [::]:80 ipv6only=on default_server;
Do you have Wordpress running? Looking at the return headers I think your web-software is redirecting from HTTPS to HTTP again, probably an error in the configuration.
I suggest to disable the HTTP to HTTPS redirect in the Apache configuration temporarily by commenting it out, so you can reach your site control panel and check if you can change the settings. If Wordpress (just guessing here, perhaps you run other software) is redirecting to HTTPS (or at least it doesn’t redirect back to HTTP), you can choose to enable the HTTP to HTTPS redirect in your Apache again.
If your server block isn't used, you have to check your complete configuration.
And checking your domain - see the output - a wrong redirect https -> https you have to find and remove.
