Err_too_many_redirects
My domain is: jonsson.am www.jonsson.am
I ran this command: jonsson.am
It produced this output: ERR_TOO_MANY_REDIRECTS
My web server is (include version): nginx version: nginx/1.18.0
The operating system my web server runs on is (include version): Debian GNU/Linux 11
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.12.0
I have installed nginx, certbot. The only things (to my knowledge) that I have done to differ from an unmodified install is:
mkdir /var/www/jonsson
echo "<h1>Hello World!</h1>" > /var/www/jonsson/index.html
echo "server {
	listen 80 ;
	listen [::]:80 ;
	root /var/www/jonsson;
	index index.html index.htm ;
	server_name jonsson.am www.jonsson.am;
		try_files $uri $uri/ =404;
}" > /etc/nginx/sites-available/jonsson
ln -s /etc/nginx/sites-available/jonsson /etc/nginx/sites-enabled/jonsson
systemctl reload nginx
certbot --nginx
# default settings
I'd be grateful if you could offer some help. At present the server file (after certbot is finished with it) looks like this
    ssl_certificate /etc/letsencrypt/live/jonsson.am/fullchain.pem; # managed by Certbot
    ssl_certificate_key /etc/letsencrypt/live/jonsson.am/privkey.pem; # managed by Certbot
    if ($host = www.jonsson.am) {
    } # managed by Certbot
    if ($host = jonsson.am) {
	listen 80 ;
	listen [::]:80 ;
Please let me know if I should provide the DNS-records or anything else. It's the first time I try certbot; would be pleased if I could learn to use it for all projects.
Go to Cloudflare and set your SSL security setting to "Full (Strict)" instead of "Flexible".
The redirect is being caused by Cloudflare talking to your webserver over HTTP instead of HTTPS.
If you could upgrade your Certbot to 1.13.0 or newer that would help too, because that will make it possible for you to renew your certificate while having the "Full (Strict)" setting enabled. i.e. by following these instructions.
Hello @jonxxon, welcome to the Let's Encrypt community. :slightly_smiling_face:
Your redirection is in what seems to be an infinite loop
With curl
$ curl -Ii http://jonsson.am/.well-known/acme-challenge/sometestfile
Date: Tue, 07 Feb 2023 21:28:34 GMT
Content-Type: text/html
Location: https://jonsson.am/.well-known/acme-challenge/sometestfile
CF-Cache-Status: DYNAMIC
Report-To: {"endpoints":[{"url":"https:\/\/a.nel.cloudflare.com\/report\/v3?s=81KeNEFXJkj6g7hawIj4Y1Q6uT%2BbPNFMTcMTCFqe4aZY4DcNXfw0z6RpW%2B7xyCGFRQvJC7wKhB%2BUNiUoJxMLgKthUEtbDYmyi3SgBSrOHotODR0HVQuNQTajIS8a"}],"group":"cf-nel","max_age":604800}
NEL: {"success_fraction":0,"report_to":"cf-nel","max_age":604800}
Server: cloudflare
CF-RAY: 795f37504a6eef14-PDX
alt-svc: h3=":443"; ma=86400, h3-29=":443"; ma=86400
Date: Tue, 07 Feb 2023 21:27:32 GMT
Report-To: {"endpoints":[{"url":"https:\/\/a.nel.cloudflare.com\/report\/v3?s=ty7vU%2BRBRLZFRTfQEuX3s4gtGTul8xnFpHZQ6x7P%2Fj7U4Fyc%2BGbW%2Fr%2FHaJ3VJsG8hxdB9uLLCoeLo4vgVV0D%2FMw5fpptpl9xdiK3O33vbSbZzgxy6vkkSVyg4P3c"}],"group":"cf-nel","max_age":604800}
Server: cloudflare
CF-RAY: 795f35c9295bef98-PDX
Using this online tool https://www.redirect-checker.org/
