ERR_TOO_MANY_REDIRECTS afer setting up certbot
My domain is: www.asteroidminingindustries.xyz
I ran this command:sudo certbot --nginx
It produced this output: ERR_TOO_MANY_REDIRECTS (on webpage no error in console)
My web server is (include version): certbot 2.6.0
The operating system my web server runs on is (include version): Ubuntu 22.04.3 LTS
My hosting provider, if applicable, is: hetzner (for the box) namecheap (for the domain)
Powershell
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): output from certbot --version = certbot 2.6.0
I had a server before with this domain and it worked fine did some updates that required me to build it again from scratch and got it working with HTTP when I try and add certbot to let it be HTTPS it gives me ERR_TOO_MANY_REDIRECTS far as I can tell I'm not using Cloudflare my redirects on the domain seem to be set correctly and now I'm lost as I'm running another instance of the same server on a different box from the same hosting services and same set up just with a different domain and that is working fine the only difference between the two is that one is a new domain and the other in an old domain
There's some misconfiguration in either nginx or the application you're using. Your certificate is installed just fine, tho.
❯ curl -IL www.asteroidminingindustries.xyz
Server: nginx/1.18.0 (Ubuntu)
Date: Fri, 01 Sep 2023 10:25:47 GMT
Content-Type: text/html
Content-Length: 178
HTTP/1.1 302 Found
Date: Fri, 01 Sep 2023 10:25:48 GMT
Content-Type: text/html; charset=utf-8
Content-Length: 0
X-Frame-Options: DENY
Vary: Accept-Language, Cookie
Content-Language: en
X-Content-Type-Options: nosniff
Referrer-Policy: same-origin
Cross-Origin-Opener-Policy: same-origin
Set-Cookie: messages=.eJw9zbEOgzAMBNBfsTK1UoQy0A_o0IG5I0LICi6kAofaTiX-vlCpne_dXdu6vn9q5n4hVRzJ-eDr4N212ATEMRc2EhoAGUgkC6yS424Tj7DlIiD0KqTmYZ0JlcBkAxwxcQXNA2yiX49Ek5r-YcxsGO1LcFgS76mgZdEKTpcQoDmuGWe4k7xJ4HbsnF3XfQBK8EEM:1qc1LY:LnKoaRFx8zy4kirq7E0svHki47w5tyESigRfmGCytC0; HttpOnly; Path=/; SameSite=Lax
HTTP/1.1 302 Found
Content-Length: 0
HTTP/1.1 302 Found
Content-Length: 0
HTTP/1.1 302 Found
Content-Length: 0
HTTP/1.1 302 Found
Content-Length: 0
HTTP/1.1 302 Found
Content-Length: 0
HTTP/1.1 302 Found
Date: Fri, 01 Sep 2023 10:25:49 GMT
Content-Length: 0
Set-Cookie: messages=.eJw9zbEOgzAMBNBfsTK1UoQy0A_o0IG5I0LICi6kAofaTiX-vlCpne_dXdu6vn9q5n4hVRzJ-eDr4N212ATEMRc2EhoAGUgkC6yS424Tj7DlIiD0KqTmYZ0JlcBkAxwxcQXNA2yiX49Ek5r-YcxsGO1LcFgS76mgZdEKTpcQoDmuGWe4k7xJ4HbsnF3XfQBK8EEM:1qc1LZ:1b62xle8yijYriPORWJf411ioGp7Xc1o_vbJYO1pP-I; HttpOnly; Path=/; SameSite=Lax
HTTP/1.1 302 Found
Content-Length: 0
HTTP/1.1 302 Found
Content-Length: 0
(It goes on)
I'm a new person to all of this and iv stumbled my way through setting this all up is there any way that I should check to see if I can find the problem to fix it? ty for the confirmation that it is installed right
Check your nginx config for some return 302 blabla statements, and show us.
server_name www.asteroidminingindustries.xyz;
location = /favicon.ico { access_log off; log_not_found off; }
location /static {
    alias /var/www/myauth/static;
    autoindex off;
location /robots.txt {
    alias /var/www/myauth/static/robots.txt;
# Gunicorn config goes below
    include proxy_params;
    proxy_pass http://127.0.0.1:8000;
ssl_certificate /etc/letsencrypt/live/www.asteroidminingindustries.xyz/fullchain.pem; # managed by Certbot
ssl_certificate_key /etc/letsencrypt/live/www.asteroidminingindustries.xyz/privkey.pem; # managed by Certbot
if ($host = www.asteroidminingindustries.xyz) {
} # managed by Certbot
listen 80;
listen [::]:80;
I believe this is the right config file
This looks ok. Check gunicorn and its redirects too?
i cant find a file called gunicorn.config or gunicorn.config.py but I have got this that is related to running gunicorn
[program:gunicorn]
user = allianceserver
directory=/home/allianceserver/myauth/
command=/home/allianceserver/venv/auth/bin/gunicorn myauth.wsgi --workers=3 --timeout 120
stdout_logfile=/home/allianceserver/myauth/log/gunicorn.log
stderr_logfile=/home/allianceserver/myauth/log/gunicorn.log
autostart=true
autorestart=true
stopsignal=INT
and this is the only thing that i have set in relation to gunicorn
if it helps im working off this install guide Gunicorn — Alliance Auth documentation
your python app, then.
ot the proxy_params file, wherever it is.
something is issuing these redirects (maybe it doesn't expect a reverse proxy, check the documentation)
