Malhar
August 29, 2019, 7:40am
1
Please fill out the fields below so we can help you better. Note: you must provide your domain name to get help. Domain names for issued certificates are all made public in Certificate Transparency logs (e.g. https://crt.sh/?q=example.com ), so withholding your domain name here does not increase secrecy, but only makes it harder for us to provide help.
My domain is:app1.toolsberry.com
I ran this command: certbot --nginx -d app1.toolsberry.com
It produced this output: successfully security key generated
The operating system my web server runs on is (include version):centos 7
I can login to a root shell on my machine (yes or no, or I don’t know):Yes
Hi @Malhar
checking your domain there is no redirect visible - https://check-your-website.server-daten.de/?q=app1.toolsberry.com
Grade H and N, because the certificate isn't valid.
CN=app.monsterdata.co
20.08.2019
18.11.2019
expires in 81 days app.monsterdata.co - 1 entry
has the wrong name.
But no loop (Grade L).
Malhar
August 29, 2019, 7:52am
3
Hello, Thanks but i dont understand what you are saying???
Grade H and N, because the certificate isn’t valid.???
Now your domain is checked again. Now there is a Grade B, so the certificate is valid.
Yep, there is it:
CN=app1.toolsberry.com
28.08.2019
26.11.2019
expires in 89 days app1.toolsberry.com - 1 entry
And a redirect http -> https without a loop, so no Grade H.
Malhar
August 29, 2019, 8:34am
5
now app1.toolsberry.com page is looking fine. but when i am loging on it, it will give error The page isn’t redirecting properly
Then it's a bug in your - not visible - application you have to fix.
system
Closed
September 28, 2019, 9:29am
7
