Too many redirections
My domain is:app.forcebase.io
I ran this command: no any command run
It produced this output: too many redirection
My web server is (include version): nginx/1.12.2
The operating system my web server runs on is (include version):centos7
My hosting provider, if applicable, is:cloudflare
I’m using a control panel to manage my site (no, or provide the name and version of the control panel):no
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot):certbot 0.34.2
Hi @Malhar
checking your domain via https://check-your-website.server-daten.de/?q=app.forcebase.io there is no redirect visible.
http://app.forcebase.io/ 45.79.23.23 301 https://app.forcebase.io/ Html is minified: 108,19 % 0.320 A
https://app.forcebase.io/ 45.79.23.23 No GZip used - 1803 / 5327 - 33,85 % possible Inline-JavaScript (∑/total): 2/2159 Inline-CSS (∑/total): 0/0 200 Html is minified: 201,02 % 5.950 B
small visible content (num chars: 59)
Don't have an account? Signup free Sign In Forgot password?
Grade B, that's good. A loop would be Grade L.
Creating a screenshot works.
So if you see a loop, use another browser or clear your browser cache.
I cleared browser many times, But issue is that, when I directly open app.forcebas.io its working.
BUT from my website, I open this link then it gives me error i.e Too many redirection
means FROm my website Its not redirecting, I insertes URL of app.forcebase.io
Do you have a link?
Online tools start new. So there is no caching effect.
yes, https://www.forcebase.io/activate-your-account/?t=d0c1b2e64211ec4611a45ec1cf051010
Checked that url manual:
D:\temp>download "https://www.forcebase.io/activate-your-account/?t=d0c1b2e64211ec4611a45ec1cf051010" -h
Transfer-Encoding: chunked
Access-Control-Allow-Origin: *
Cache-Control: no-store, no-cache, must-revalidate, max-age=0,post-check=0, pre-check=0
Date: Fri, 15 May 2020 10:56:25 GMT
Server: nginx
X-Powered-By: PHP/7.1.29
Pragma: no-cache
Set-Cookie: PHPSESSID=39077dd835bbf6aefe3f2f1117e165a9; path=/
Location: https://app.forcebase.io/app-login/d0c1b2e64211ec4611a45ec1cf051010
Strict-Transport-Security: max-age=63072000
Status: 302 Redirect
2117,65 milliseconds
2,12 seconds
D:\temp>download "https://app.forcebase.io/app-login/d0c1b2e64211ec4611a45ec1cf051010" -h
Pragma: no-cache
Content-Type: text/html;charset=UTF-8
Date: Fri, 15 May 2020 10:57:07 GMT
Expires: Thu, 19 Nov 1981 08:52:00 GMT
Set-Cookie: PHPSESSID=d36059ad94de3369a0819729f09f5765; path=/
Server: nginx
Status: 200 OK
There is one redirect, then a http status 200, not a second redirect.
But my browser shows a redirect - https://app.forcebase.io/dashboard/.
So your application creates cookies and redirects -> fix your application.
okay, Thank you verry much sir
