Timeout during connect
My domain is: gosocialmedia.pl
I ran this command: certbot certainly -d gosocialmedia.pl
During secondary validation: 91.236.87.76: Fetching http://gosocialmedia.pl/.well-known/acme-challenge/<...> Timeout during connect (likely firewall problem)
My web server is (include version): Apache 2.4.53
The operating system my web server runs on is (include version): Rocky Linux 9.2 (Blue Onyx)
My hosting provider, if applicable, is: n/a
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 2.6.0
I've already checked:
  1. ports 80,443 are open and accessible from internet
  2. Wireshark shows that apache receives GET request for a challenge file from lets encrypt server and replies successfully with its content
  3. I can access other test files from directory .well-known/acme-challenge using browser
What is the issue????
Regards,
Rafał
Hi @Rafal,
Welcome to our community! :slightly_smiling_face:
From around the world Permanent link to this check report shows HTTP not able to connect.
Hi Bruce!
thanks for warm welcome! :slightly_smiling_face:
This is strange, I've used browser connected to external mobile phone network and it works...it may be cached? I will double check it...
Best regards,
Rafał
Or there is geoblocking going on.
Thank you all for your help! It turned out it was my firewall configuration issue, now it works perfectly! Issue closed!
