My domain is: naspibagel.page
Then of course I chose my domain
Domain: naspibagel.page
Type: connection
Detail: Fetching
http://naspibagel.page/.well-known/acme-challenge/6fUwpMM9Wsi8MWGCQZVokdDj088GiMDm_NmZ_WKXZO0:
My web server is (include version): Apache2.4.38
The operating system my web server runs on is (include version): Raspbian
My hosting provider, if applicable, is: Google Domains
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 0.31.0
I think I'm getting a timeout error because of port 80. I can't seem to get it to forward correctly. I have verified with my ISP and my router manufacturer that they are not blocking port 80. I have configured port forwarding on 80 through my router as they suggested. I am having no problems forwarding port 443 and it is configured the same way 80 is. I've also allowed 80 and 443 on ufw and have a static ip.
sudo ufw status
Status: active
To Action From
22 ALLOW 192.168.0.28
80 ALLOW Anywhere
443 ALLOW Anywhere
80 (v6) ALLOW Anywhere (v6)
443 (v6) ALLOW Anywhere (v6)
