Timeout during connect
My domain is: ticket01.thismonitor.net
I ran this command: sudo certbot certonly --webroot -w /var/www/osTicket/upload -d ticket01.thismonitor.net
Certbot failed to authenticate some domains (authenticator: webroot). The Certif icate Authority reported these problems:
Domain: ticket01.thismonitor.net
Type: connection
Detail: 43.251.xxx.xxx: Fetching http://ticket01.thismonitor.net/.well-known/acm e-challenge/tFKq-axWe2WrjTFZU82ta3XDCUoEZpFWyCdiGIlagDA: Timeout during connect (likely firewall problem)
My web server is (include version): apache2.4
The operating system my web server runs on is (include version): ubuntu 22.04
The default HTTP domain validation method requires public HTTP access to your sites, so that means TCP port 80 has to be open and http requests have to reach your server. With the webroot method your own web server has to respond with the challenge response file, so that also means it needs to be listening for http on TCP port 80.
If you update your server configuration to allow http requests for your site the validation will probably work as long as the path you are providing is correct.
Alternatively you can use DNS validation (automatically updating a TXT record in response to the domain validation challenge), you're using AWS so you should be able to use a plugin like this: Welcome to certbot-dns-route53’s documentation! — certbot-dns-route53 0 documentation
Hi Bro,
TCP 80 is opened
tcping ticket01.thismonitor.net 80
Probing 43.251.65.65:80/tcp - Port is open - time=3.423ms
Probing 43.251.65.65:80/tcp - Port is open - time=1.707ms
Probing 43.251.65.65:80/tcp - Port is open - time=0.854ms
Probing 43.251.65.65:80/tcp - Port is open - time=1.085ms
But still getting the same error.
Can you help me check please?
Do you have Geo-Location blocking?
Where did you test from?
I get:
curl -Ii ticket01.thismonitor.net
LD sees:
Let's Debug (letsdebug.net)
How can I check if I have Geo-location blocking?
Do you know what defenses are enabled on your system?
Do you know what devices are inline that protect your IP?
I tested from our office IP's and with VPN from Korea, Turkey and others.
Im able to access.
But my problem is unable to get certificate
Ticket01.thismonitor.net - Is Ticket01 Down Right Now? (isitdownrightnow.com)
LE needs to reach your site.
It can't reach it:
LD can't reach it:
Usually the easiest way to check is to run https://letsdebug.net which will check to see if you're site is accessible outside your own network. You can also just try using your phones mobile data instead of your wifi to access your site as http:// - it doesn't matter if your site works on your office network, because Let's Encrypt are not on your office network.
As an aside, for native English speakers "Bro" is generally considered a confrontational or negative form of address and is not how to ask for help :slight_smile:
Do you know how can i solve this?
im having a hard time to resolve this since i allowed port 80 already on my firewall
Can i try to use DNS-01 for this issue for now?
