finance.gkp.pk
sudo certbot --nginx
Domain: ebills.finance.gkp.pk
Type: connection
Detail: 175.107.63.149: Fetching http://ebills.finance.gkp.pk/.well-known/acme-challenge/zP2QGlWn54kBAqMtSBYc4j51nDV8YOaQXxp4NSTcTFY: Timeout during connect (likely firewall problem)
Domain: finance.gkp.pk
Type: connection
Detail: 175.107.63.149: Fetching http://finance.gkp.pk/.well-known/acme-challenge/o6H2kCt9J0iwPZUwLIvyd9DAbXAgA8BfzT0BhfD19fo: Timeout during connect (likely firewall problem)
Domain: fmr.finance.gkp.pk
Type: connection
Detail: 175.107.63.149: Fetching http://fmr.finance.gkp.pk/.well-known/acme-challenge/aL2QxPvZ0CkQKZoEbonh58aHIkP9l8vRDlzEBFTUBuo: Timeout during connect (likely firewall problem)
Domain: gfc.finance.gkp.pk
Type: connection
Detail: 175.107.63.149: Fetching http://gfc.finance.gkp.pk/.well-known/acme-challenge/UfGxedpnOGnZoBPqanXOHkuPjuRIng1yn2PJUJwhIoU: Timeout during connect (likely firewall problem)
Domain: mis.finance.gkp.pk
Type: connection
Detail: 175.107.63.149: Fetching http://mis.finance.gkp.pk/.well-known/acme-challenge/EwyGpnBMpBBAf2ye-AfNmN4ljyGB4VwesXZWKoGLknQ: Timeout during connect (likely firewall problem)
Domain: om.finance.gkp.pk
Type: connection
Detail: 175.107.63.149: Fetching http://om.finance.gkp.pk/.well-known/acme-challenge/S9RsgHYmRhl-GDz45BD5Rmk5BmyOsty5MX4llvdnqs8: Timeout during connect (likely firewall problem)
Domain: www.ebills.finance.gkp.pk
Type: connection
Detail: 175.107.63.149: Fetching http://www.ebills.finance.gkp.pk/.well-known/acme-challenge/5OlyydmRSrpEdHt9zNuiwc5ykGDHbCiNjZAkaeA6sRs: Timeout during connect (likely firewall problem)
Domain: www.finance.gkp.pk
Type: connection
Detail: 175.107.63.149: Fetching http://www.finance.gkp.pk/.well-known/acme-challenge/8oxZoRxkSwBK7AFG6zmIX6SPTt1fdfmGMXjbMcuG9zs: Timeout during connect (likely firewall problem)
Domain: www.fmr.finance.gkp.pk
Type: connection
Detail: 175.107.63.149: Fetching http://www.fmr.finance.gkp.pk/.well-known/acme-challenge/zoP8__6rfZ9gPketuAjviTm-3LFweE_LOEPmtK_xUKM: Timeout during connect (likely firewall problem)
Domain: www.gfc.finance.gkp.pk
Type: connection
Detail: 175.107.63.149: Fetching http://www.gfc.finance.gkp.pk/.well-known/acme-challenge/VxHJk2OBDJqtfKDQ3CLxqL9AHjTVon05CJIIhwZgdoM: Timeout during connect (likely firewall problem)
Domain: www.mis.finance.gkp.pk
Type: connection
Detail: 175.107.63.149: Fetching http://www.mis.finance.gkp.pk/.well-known/acme-challenge/BEK30rfFwsijJfT6kTDIu6dvTk3Ms0I949EtLGKfcAY: Timeout during connect (likely firewall problem)
Domain: www.om.finance.gkp.pk
Type: connection
Detail: 175.107.63.149: Fetching http://www.om.finance.gkp.pk/.well-known/acme-challenge/Og1DHMaUFe9GhNmIiq8EHKj0ZCDC-hC2qr34Tr-peoc: Timeout during connect (likely firewall problem)
nginx version: nginx/1.14.0 (Ubuntu)
Ubuntu 18.04
Yes
No
certbot 2.8.0
For some reason, I have deleted my certificates. I also uninstalled certbot and deleted all the directories, I then reinstalled certbot and now facing this issue, please help...
The website is accessible on: http://www.finance.gkp.pk/ and also on ip: 175.107.63.149/
Hi! Your website is unreachable from my vantage point as it isn't from Lets Debug's:
Perhaps there's some kind of geo blocking features enabled somewhere on your side?
I concur. From my location the website is accessible, but if you look at e.g. Website Availability Test - Check Website Uptime | Uptimia, you can see it's only accessible from 25 out of 35 locations. Not really geographically different, but perhaps some other block list is being used. Maybe based on provider? I dunno. In any case it's most likely a firewall issue.
Don't have any clue where the problem exists, but still unable to get the certificates, please help me identify the problem...thank you
This is as far as we can help you I'm afraid. Generic website connectivity issues are not our speciality.
Once your website is accessible by anyone around the globe, you'd fix your certificate issue (at least this one).
You might have luck with one of the other free CAs.
