My domain is: panel.widegames.eu
I ran this command: sudo certbot --nginx -v
1: panel.widegames.eu
Requesting a certificate for panel.widegames.eu
http-01 challenge for panel.widegames.eu
Challenge failed for domain panel.widegames.eu
Domain: panel.widegames.eu
Type: connection
Detail: During secondary validation: 152.89.254.136: Fetching http://panel.widegames.eu/.well-known/acme-challenge/xt5a5DH1YR*******************SgLwfzM: Timeout during connect (likely firewall problem)
The operating system my web server runs on is (include version): Ubuntu 22.04
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.11.0
I should also add that I disabled the firewall to carry out further tests but with the same result.
Below is my freshly generated configuration file:
listen 80;
listen [::]:80;
root /var/www/panel.widegames.eu/html;
server_name panel.widegames.eu www.panel.widegames.eu;
try_files $uri $uri/ =404;
