chitatel.by uchitel.by
I tried to get certificates for both one and the second domain
certbot -i nginx -v --authenticator manual
Afterwards I tried the commands:
certbot certonly --webroot -w /var/www/letsencrypt -d uchitel.by -d www.uchitel.by
and : certbot --nginx
Domain: chitatel.by
Type: connection
Detail: During secondary validation: 178.163.229.75: Fetching http://chitatel.by/.well-known/acme-challenge/Z_JQdBm1EzpaM8CZ0bdRRuN61XMLGJhMlxboD9Q8mmI: Timeout during connect (likely firewall problem)
nginx/1.18.0 (Ubuntu)
22.04.5 LTS (Jammy Jellyfish)
A1 Digital Services FLLC
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.21.0
I checked that my site responds to the request for URI .well-known/acme-challenge - get 200
last time I got such nginx logs
в последний раз я у себя получал такие логи nginx
23.178.112.100 - - [30/Jan/2025:15:32:20 +0000] "GET /.well-known/acme-challenge/KNDT6Vvw8XeKp6V20mBIBMUOI9UGaKvYdTkVej2BZuM HTTP/1.1" 200 88 "-" "Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)"
23.178.112.105 - - [30/Jan/2025:15:32:20 +0000] "GET /.well-known/acme-challenge/Z_JQdBm1EzpaM8CZ0bdRRuN61XMLGJhMlxboD9Q8mmI HTTP/1.1" 200 88 "-" "Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)"
54.255.240.216 - - [30/Jan/2025:15:32:22 +0000] "GET /.well-known/acme-challenge/KNDT6Vvw8XeKp6V20mBIBMUOI9UGaKvYdTkVej2BZuM HTTP/1.1" 200 88 "-" "Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)"
54.255.240.216 - - [30/Jan/2025:15:32:22 +0000] "GET /.well-known/acme-challenge/Z_JQdBm1EzpaM8CZ0bdRRuN61XMLGJhMlxboD9Q8mmI HTTP/1.1" 200 88 "-" "Mozilla/5.0 (compatible; Let's Encrypt validation server; +https://www.letsencrypt.org)"
But despite this, the сукеище gives an error:
Press Enter to Continue
Challenge failed for domain chitatel.by
Challenge failed for domain www.chitatel.by
http-01 challenge for chitatel.by
http-01 challenge for www.chitatel.by
Domain: chitatel.by
Type: connection
Domain: www.chitatel.by
Type: connection
Detail: During secondary validation: 178.163.229.75: Fetching http://www.chitatel.by/.well-known/acme-challenge/KNDT6Vvw8XeKp6V20mBIBMUOI9UGaKvYdTkVej2BZuM: Timeout during connect (likely firewall problem)
Hint: The Certificate Authority failed to verify the manually created challenge files. Ensure that you created these in the correct location.
Hello @Esserg, welcome to the Let's Encrypt community. :slightly_smiling_face:
You are using the HTTP-01 challenge which states "The HTTP-01 challenge can only be done on port 80."
There seems to be Geo Blocking shown here Permanent link to this check report and here Permanent link to this check report.
Please read these:
Edit
And using the online tool Let's Debug yields these results https://letsdebug.net/chitatel.by/2350920 and https://letsdebug.net/uchitel.by/2350921
