My domain is: dhis2.nih.org.pk
I ran this command: sudo certbot-auto --nginx -d dhis2.nih.org.pk
http-01 challenge for dhis2.nih.org.pk
Challenge failed for domain dhis2.nih.org.pk
   Domain: dhis2.nih.org.pk
   Type:   connection
   Detail: Fetching
   http://dhis2.nih.org.pk/.well-known/acme-challenge/enj2RtrqkMkOxR3AQbkgt84PP45UJIBKwiKskGxl7aY:
My web server is (include version): nginx/1.14.0 (Ubuntu)
My hosting provider, if applicable, is: Digital Ocean
I have had problems previously with renewing certificates on this server but the command used above worked for me last time I think.
This time after trying many options in desperation I have deleted the certificate and tried to create a new one but I am having the same timeout issue. I suspect this is a web server configuration issue rather than a Let’s Encrypt issue but would welcome any help.
My nginx configuration is:
# apply these settings to all backends
proxy_cache_path  /var/cache/nginx  keys_zone=dhis:250m  inactive=1d;
proxy_redirect    off;
proxy_set_header  Host               $host;
proxy_set_header  X-Real-IP          $remote_addr;
proxy_set_header  X-Forwarded-For    $proxy_add_x_forwarded_for;
proxy_set_header  X-Forwarded-Proto  https;
proxy_cookie_path / "/; secure";
#proxy_cache       dhis;
# redirect http to https server
  listen     80 default_server;
  listen     [::]:80;
  # rewrite    ^ https://$host$request_uri? permanent;
  # redirect all HTTP requests to HTTPS with a 301 Moved Permanently response.
# HTTPS server
  listen               443 ssl http2;
  listen               [::]:443 ssl http2 default_server;
  root /home/dhis/tomcat-dhis/webapps/ROOT;
  server_name dhis2.nih.org.pk;
  client_max_body_size 400M;
  # ssl stuff
  ssl                  on;
     ssl_certificate /etc/letsencrypt/live/dhis2.nih.org.pk/fullchain.pem; # managed by Certbot
    ssl_certificate_key /etc/letsencrypt/live/dhis2.nih.org.pk/privkey.pem; # managed by Certbot
  ssl_session_timeout  30m;
  # ssl_protocols              TLSv1 TLSv1.1 TLSv1.2;
  ssl_session_cache shared:SSL:20m;
  # ssl_prefer_server_ciphers  on;
  # You need to generate the dh parameters before using this setting
  # Command:  openssl dhparam -out /etc/ssl/certs/dhparam.pem 2048
  ssl_dhparam /etc/ssl/certs/dhparam.pem;
  # intermediate configuration
    ssl_ciphers ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384;
    ssl_prefer_server_ciphers off;
    # HSTS (ngx_http_headers_module is required) (63072000 seconds)
    add_header Strict-Transport-Security "max-age=63072000" always;
    # OCSP stapling
    ssl_stapling on;
    ssl_stapling_verify on;
  # Serve static files
  location ~ (\.js|\.css|\.gif|\.woff|\.ttf|\.eot|\.ico|(/dhis-web-commons/|/images/|/icons/).*\.png)$ {
   add_header  Cache-Control public;
    expires     14d;
  # Proxy pass to servlet container
    # proxy_pass                http://localhost:8080/;
    proxy_pass                http://127.0.0.1:8080/;
    proxy_redirect            off;
    proxy_buffer_size         128k;
    proxy_buffers             8 128k;
    proxy_busy_buffers_size   256k;
    proxy_read_timeout 5m;
  # This is quite strict.  If you have much older windoze browsers
  # to support you might need the line below instead.
  # ssl_ciphers 'EECDH+AESGCM:EDH+AESGCM:AES256+EECDH:AES256+EDH';
  # ssl_ciphers "ECDHE-RSA-AES256-GCM-SHA384:ECDHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA256:ECDHE-RSA-AES256-SHA:ECDHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES128-SHA256:DHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES256-GCM-SHA384:AES128-GCM-SHA256:AES256-SHA256:AES128-SHA256:AES256-SHA:AES128-SHA:DES-CBC3-SHA:HIGH:!aNULL:!eNULL:!EXPORT:!DES:!MD5:!PSK:!RC4";
  # Enable HSTS
  # add_header Strict-Transport-Security max-age=63072000;
  # add_header Strict-Transport-Security "max-age=31536000; includeSubDomains";
  # Do not allow this site to be displayed in iframes
 #  add_header X-Frame-Options DENY;
  # Do not permit Content-Type sniffing.
  add_header X-Content-Type-Options nosniff always;
  # inject X-FRAME-OPTIONS in HTTP Header to prevent clickjacking attack.
  # add_header X-Frame-Options SAMEORIGIN;
  # add_header X-XSS-Protection "1;mode=block";
  # add_header Content-Security-Policy "default-src 'self'";
  # Breaks things!
  # add_header Content-Security-Policy "default-src 'self'; script-src 'self'; img-src 'self' data:; style-src 'self' 'unsafe-inline'; font-src 'self' data:; frame-src 'self'; connect-src 'self' https://apis.google.com; object-src 'none' ";
  # nominate a backend as the default
  # rewrite ^/$ /dhis/;
  # Proxy pass to servlet containers
  # location /dhis { proxy_pass  http://localhost:8080/dhis; }
The site worked fine until the certificate expired. I would set up a cron job if I could find a reliable way of renewing the certificate.
Thanks for any help,
Paul
Edit: obviously I have checked that the site is not behind a firewall.
Hi @prcleary
there are checks of your domain, last is ~~one hour old - dhis2.nih.org.pk - Make your website better - DNS, redirects, mixed content, certificates
Only timeouts:
• http://dhis2.nih.org.pk/ 115.186.130.3 -14 10.120 T
Timeout - The operation has timed out
• https://dhis2.nih.org.pk/ 115.186.130.3 -14 10.443 T
• http://dhis2.nih.org.pk/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 115.186.130.3 -14 10.037 T
Visible Content:
Works http internal? What says
curl http://dhis2.nih.org.pk/.well-known/acme-challenge/1234
from that machine?
There is (1) a wrong router config and / or (2) a blocking firewall or something else. You have to find that and remove it.
Thanks very much for the quick reply Juergen. The curl command times out. My colleagues in another timezone where this is hosted assured me that they had bypassed the firewall but I have asked them to check the port forwarding as well. I will have to wait to try again tomorrow.
Edit: of course you meant me to run the curl command on the server itself: I get a 301 error from that
They did something at the other end (waiting to find out what) and I was able to renew the certificate. Thanks again, Paul
Apparently it was an error in the port forwarding
